旋转对象 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 631| 评论: 0|原作者: admin|来自: AutoCAD
旋转对象 (.NET)
可以旋转所有图形对象和属性参照对象。
要旋转对象,请使用变换矩阵的函数。此函数需要以弧度表示的旋转角度、旋转轴和基点。旋转轴必须表示为对象,基点必须表示为对象。此角度决定了对象相对于其当前位置围绕基点旋转的距离。RotationVector3dPoint3d
绕基点旋转折线
本示例创建闭合的轻量级折线,然后将折线绕基点 (4, 4.25, 0) 旋转 45 度。
VB.NET
<CommandMethod("RotateObject")> _
Public Sub RotateObject()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a lightweight polyline
        Using acPoly As Polyline = New Polyline()
            acPoly.AddVertexAt(0, New Point2d(1, 2), 0, 0, 0)
            acPoly.AddVertexAt(1, New Point2d(1, 3), 0, 0, 0)
            acPoly.AddVertexAt(2, New Point2d(2, 3), 0, 0, 0)
            acPoly.AddVertexAt(3, New Point2d(3, 3), 0, 0, 0)
            acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0)
            acPoly.AddVertexAt(5, New Point2d(4, 2), 0, 0, 0)
            '' Close the polyline
            acPoly.Closed = True
            Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
            Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d
            '' Rotate the polyline 45 degrees, around the Z-axis of the current UCS
            '' using a base point of (4,4.25,0)
            acPoly.TransformBy(Matrix3d.Rotation(0.7854, _
                                                 curUCS.Zaxis, _
                                                 New Point3d(4, 4.25, 0)))
            acBlkTblRec.AppendEntity(acPoly)
            acTrans.AddNewlyCreatedDBObject(acPoly, True)
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("RotateObject")]
public static void RotateObject()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a lightweight polyline
        using (Polyline acPoly = new Polyline())
            acPoly.AddVertexAt(0, new Point2d(1, 2), 0, 0, 0);
            acPoly.AddVertexAt(1, new Point2d(1, 3), 0, 0, 0);
            acPoly.AddVertexAt(2, new Point2d(2, 3), 0, 0, 0);
            acPoly.AddVertexAt(3, new Point2d(3, 3), 0, 0, 0);
            acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0);
            acPoly.AddVertexAt(5, new Point2d(4, 2), 0, 0, 0);
            // Close the polyline
            acPoly.Closed = true;
            Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
            CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
            // Rotate the polyline 45 degrees, around the Z-axis of the current UCS
            // using a base point of (4,4.25,0)
                                                 curUCS.Zaxis,
                                                 new Point3d(4, 4.25, 0)));
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub RotateObject()
    ' Create the polyline
    Dim points(0 To 11) As Double
    points(0) = 1: points(1) = 2
    points(2) = 1: points(3) = 3
    points(4) = 2: points(5) = 3
    points(6) = 3: points(7) = 3
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 2
    Set plineObj = ThisDrawing.ModelSpace. _
                                    AddLightWeightPolyline(points)
    plineObj.Closed = True
    ZoomAll
    ' Define the rotation of 45 degrees about a
    ' base point of (4, 4.25, 0)
    Dim basePoint(0 To 2) As Double
    Dim rotationAngle As Double
    basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
    rotationAngle = 0.7853981   ' 45 degrees
    plineObj.Rotate basePoint, rotationAngle
    plineObj.Update
GMT+8, 2026-10-27 05:15
