擦除对象 (.NET)
您可以使用该方法删除非图形和图形对象。Erase 谨慎:虽然许多非图形对象(如图层表和模型空间块表记录)具有方法,但不应调用该方法。如果在其中一个对象上调用,则会发生错误。EraseErase
创建和擦除折线本示例创建轻量级折线,然后擦除它。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("EraseObject")> _
Public Sub EraseObject()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a lightweight polyline
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, New Point2d(2, 4), 0, 0, 0)
acPoly.AddVertexAt(1, New Point2d(4, 2), 0, 0, 0)
acPoly.AddVertexAt(2, New Point2d(6, 4), 0, 0, 0)
acBlkTblRec.AppendEntity(acPoly)
acTrans.AddNewlyCreatedDBObject(acPoly, True)
'' Update the display and display an alert message
acDoc.Editor.Regen()
Application.ShowAlertDialog("Erase the newly added polyline.")
'' Erase the polyline from the drawing
acPoly.Erase(True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("EraseObject")]
public static void EraseObject()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a lightweight polyline
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, new Point2d(2, 4), 0, 0, 0);
acPoly.AddVertexAt(1, new Point2d(4, 2), 0, 0, 0);
acPoly.AddVertexAt(2, new Point2d(6, 4), 0, 0, 0);
acBlkTblRec.AppendEntity(acPoly);
acTrans.AddNewlyCreatedDBObject(acPoly, true);
// Update the display and display an alert message
acDoc.Editor.Regen();
Application.ShowAlertDialog("Erase the newly added polyline.");
// Erase the polyline from the drawing
acPoly.Erase(true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub EraseObject()
' Create the polyline
Dim lwpolyObj As AcadLWPolyline
Dim vertices(0 To 5) As Double
vertices(0) = 2: vertices(1) = 4
vertices(2) = 4: vertices(3) = 2
vertices(4) = 6: vertices(5) = 4
Set lwpolyObj = ThisDrawing.ModelSpace. _
AddLightWeightPolyline(vertices)
ZoomAll
lwpolyObj.Delete
ThisDrawing.Regen acActiveViewport
父主题: |
GMT+8, 2026-10-27 09:12
