扩展数据筛选器 (.NET)
外部应用程序可以将文本字符串、数值、三维点、距离和图层名称等数据附着到 AutoCAD 对象。此数据称为扩展数据或 xdata。您可以筛选包含指定应用程序的扩展数据的实体。 选择包含 xdata 的圆圈以下示例筛选包含“MY_APP”应用程序添加的 xdata 的圆圈: VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("FilterXdata")> _
Public Sub FilterXdata()
'' Get the current document editor
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Create a TypedValue array to define the filter criteria
Dim acTypValAr(1) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "Circle"), 0)
acTypValAr.SetValue(New TypedValue(DxfCode.ExtendedDataRegAppName, _
"MY_APP"), 1)
'' Assign the filter criteria to a SelectionFilter object
Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.GetSelection(acSelFtr)
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
Application.ShowAlertDialog("Number of objects selected: " & _
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects selected: 0")
End If
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("FilterXdata")]
public static void FilterXdata()
// Get the current document editor
Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
// Create a TypedValue array to define the filter criteria
TypedValue[] acTypValAr = new TypedValue[2];
acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "Circle"), 0);
acTypValAr.SetValue(new TypedValue((int)DxfCode.ExtendedDataRegAppName,
"MY_APP"), 1);
// Assign the filter criteria to a SelectionFilter object
SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
// Request for objects to be selected in the drawing area
PromptSelectionResult acSSPrompt;
acSSPrompt = acDocEd.GetSelection(acSelFtr);
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
SelectionSet acSSet = acSSPrompt.Value;
Application.ShowAlertDialog("Number of objects selected: " +
acSSet.Count.ToString());
else
Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考Sub FilterXdata()
Dim sset As AcadSelectionSet
Dim FilterType(1) As Integer
Dim FilterData(1) As Variant
Set sset = ThisDrawing.SelectionSets.Add("SS1")
FilterType(0) = 0: FilterData(0) = "Circle"
FilterType(1) = 1001: FilterData(1) = "MY_APP"
sset.SelectOnScreen FilterType, FilterData
MsgBox "Number of objects selected: " & sset.Count
' Remove the selection set at the end
sset.Delete
相关概念父主题: |
GMT+8, 2026-11-15 13:48
