添加到或合并多个选择集 (.NET)
您可以合并多个选择集,创建对象,然后将多个选择集中的对象 ID 加在一起。除了向对象添加对象 ID 外,还可以删除对象 ID。将所有对象 ID 添加到对象后,您可以循环访问对象 ID 的集合,并根据需要操作每个对象。ObjectIdCollectionObjectIdCollectionObjectIdCollection 将选定对象添加到选择集本示例提示用户选择对象两次,然后将创建的两个选择集合并为一个选择集。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("MergeSelectionSets")> _
Public Sub MergeSelectionSets()
'' Get the current document editor
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.GetSelection()
Dim acSSet1 As SelectionSet
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
'' Get the selected objects
acSSet1 = acSSPrompt.Value
'' Append the selected objects to the ObjectIdCollection
acObjIdColl = New ObjectIdCollection(acSSet1.GetObjectIds())
End If
Dim acSSet2 As SelectionSet
acSSet2 = acSSPrompt.Value
'' Check the size of the ObjectIdCollection, if zero, then initialize it
If acObjIdColl.Count = 0 Then
acObjIdColl = New ObjectIdCollection(acSSet2.GetObjectIds())
Else
Dim acObjId As ObjectId
'' Step through the second selection set
For Each acObjId In acSSet2.GetObjectIds()
'' Add each object id to the ObjectIdCollection
acObjIdColl.Add(acObjId)
Next
End If
End If
Application.ShowAlertDialog("Number of objects selected: " & _
acObjIdColl.Count.ToString())
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("MergeSelectionSets")]
public static void MergeSelectionSets()
// Get the current document editor
Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
// Request for objects to be selected in the drawing area
PromptSelectionResult acSSPrompt;
acSSPrompt = acDocEd.GetSelection();
SelectionSet acSSet1;
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
// Get the selected objects
acSSet1 = acSSPrompt.Value;
// Append the selected objects to the ObjectIdCollection
acObjIdColl = new ObjectIdCollection(acSSet1.GetObjectIds());
SelectionSet acSSet2;
acSSet2 = acSSPrompt.Value;
// Check the size of the ObjectIdCollection, if zero, then initialize it
if (acObjIdColl.Count == 0)
acObjIdColl = new ObjectIdCollection(acSSet2.GetObjectIds());
else
// Step through the second selection set
foreach (ObjectId acObjId in acSSet2.GetObjectIds())
// Add each object id to the ObjectIdCollection
acObjIdColl.Add(acObjId);
Application.ShowAlertDialog("Number of objects selected: " +
acObjIdColl.Count.ToString());
VBA/ActiveX 代码参考Sub MergeSelectionSets()
' Create a new selection set
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("SS1")
' Prompt the user to select objects
' and add them to the selection set.
sset.SelectOnScreen
' Prompt the user again to select objects
' and add them to the same selection set.
sset.SelectOnScreen
MsgBox "Number of total objects selected: " & sset.Count
' Remove the selection set at the end
sset.Delete
相关概念父主题: |
GMT+8, 2026-10-27 00:40
