选择绘图区域中的对象 (.NET)
您可以通过让用户以交互方式选择对象来选择对象,也可以通过 AutoCAD .NET API 模拟许多不同的对象选择选项。如果例程执行多个选择集,则需要跟踪返回的每个选择集,或创建一个对象来跟踪所有选定对象。以下函数允许您从图形中选择对象:ObjectIdCollection
提示屏幕上的对象并迭代选择集本示例提示用户选择对象,然后将所选每个对象的颜色更改为“绿色”或“AutoCAD 颜色索引”3。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("SelectObjectsOnscreen")> _
Public Sub SelectObjectsOnscreen()
'' Start a transaction
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection()
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
'' Step through the objects in the selection set
For Each acSSObj As SelectedObject In acSSet
'' Check to make sure a valid SelectedObject object was returned
If Not IsDBNull(acSSObj) Then
'' Open the selected object for write
Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, _
OpenMode.ForWrite)
If Not IsDBNull(acEnt) Then
'' Change the object's color to Green
acEnt.ColorIndex = 3
End If
End If
Next
'' Save the new object to the database
acTrans.Commit()
End If
'' Dispose of the transaction
End Using
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("SelectObjectsOnscreen")]
public static void SelectObjectsOnscreen()
// Start a transaction
// Request for objects to be selected in the drawing area
PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection();
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
SelectionSet acSSet = acSSPrompt.Value;
// Step through the objects in the selection set
foreach (SelectedObject acSSObj in acSSet)
// Check to make sure a valid SelectedObject object was returned
if (acSSObj != null)
// Open the selected object for write
Entity acEnt = acTrans.GetObject(acSSObj.ObjectId,
OpenMode.ForWrite) as Entity;
if (acEnt != null)
// Change the object's color to Green
acEnt.ColorIndex = 3;
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub SelectObjectsOnscreen()
' Create a new selection set
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("SS1")
' Prompt the user to select objects
' and add them to the selection set.
sset.SelectOnScreen
Dim acEnt As AcadEntity
' Step through the selected objects and change
' each object's color to Green
For Each acEnt In sset
' Use the Color property to set the object's color
acEnt.color = acGreen
Next acEnt
' Remove the selection set at the end
sset.Delete
选择具有交叉窗口的对象本示例选择交叉窗口内和与交叉窗口相交的对象。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SelectObjectsByCrossingWindow")> _
Public Sub SelectObjectsByCrossingWindow()
'' Get the current document editor
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Create a crossing window from (2,2,0) to (10,8,0)
acSSPrompt = acDocEd.SelectCrossingWindow(New Point3d(2, 2, 0), _
New Point3d(10, 8, 0))
Application.ShowAlertDialog("Number of objects selected: " & _
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects selected: 0")
End If
[CommandMethod("SelectObjectsByCrossingWindow")]
public static void SelectObjectsByCrossingWindow()
// Get the current document editor
Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
// Create a crossing window from (2,2,0) to (10,8,0)
PromptSelectionResult acSSPrompt;
acSSPrompt = acDocEd.SelectCrossingWindow(new Point3d(2, 2, 0),
new Point3d(10, 8, 0));
Application.ShowAlertDialog("Number of objects selected: " +
acSSet.Count.ToString());
else
Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考Sub SelectObjectsByCrossingWindow()
' Define the points for the crossing window
Dim pt1(0 To 2) As Double
Dim pt2(0 To 2) As Double
pt1(0) = 2#: pt1(1) = 2#: pt1(2) = 0#:
pt2(0) = 10#: pt2(1) = 8#: pt2(2) = 0#:
sset.Select acSelectionSetCrossing, pt1, pt2
MsgBox "Number of objects selected: " & sset.Count
sset.Delete
父主题: |
GMT+8, 2026-10-27 00:40
