获取 PickFirst 选择集 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 805| 评论: 0|原作者: admin|来自: AutoCAD
在启动命令之前选择对象时,将创建 PickFirst 选择集。为了获取 PickFirst 选择集的对象,必须满足几个条件,这些条件是:
  • PICKFIRST 系统变量必须设置为 1
  • UsePickSet命令标志必须使用应使用 PickFirst 选择集的命令进行定义
  • 调用该方法以获取 PickFirst 选择集SelectImplied
该方法用于清除当前的 PickFirst 选择集。SetImpliedSelection
获取 Pickfirst 选择集
本示例显示 PickFirst 选择集中的对象数,然后请求用户选择其他对象。在请求用户选择对象之前,将使用该方法清除当前的 PickFirst 选择集。SetImpliedSelection
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)> _
Public Sub CheckForPickfirstSelection()
    '' Get the current document
    Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
    '' Get the PickFirst selection set
    Dim acSSPrompt As PromptSelectionResult
    acSSPrompt = acDocEd.SelectImplied()
    Dim acSSet As SelectionSet
    '' If the prompt status is OK, objects were selected before
    '' the command was started
    If acSSPrompt.Status = PromptStatus.OK Then
        acSSet = acSSPrompt.Value
        Application.ShowAlertDialog("Number of objects in Pickfirst selection: " & _
                                    acSSet.Count.ToString())
    Else
        Application.ShowAlertDialog("Number of objects in Pickfirst selection: 0")
    End If
    '' Clear the PickFirst selection set
    Dim idarrayEmpty() As ObjectId
    acDocEd.SetImpliedSelection(idarrayEmpty)
    '' Request for objects to be selected in the drawing area
    acSSPrompt = acDocEd.GetSelection()
        Application.ShowAlertDialog("Number of objects selected: " & _
    Else
        Application.ShowAlertDialog("Number of objects selected: 0")
    End If
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)]
public static void CheckForPickfirstSelection()
    // Get the current document
    Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
    // Get the PickFirst selection set
    PromptSelectionResult acSSPrompt;
    acSSPrompt = acDocEd.SelectImplied();
    SelectionSet acSSet;
    // If the prompt status is OK, objects were selected before
    // the command was started
    if (acSSPrompt.Status == PromptStatus.OK)
        acSSet = acSSPrompt.Value;
        Application.ShowAlertDialog("Number of objects in Pickfirst selection: " +
                                    acSSet.Count.ToString());
    else
        Application.ShowAlertDialog("Number of objects in Pickfirst selection: 0");
    // Clear the PickFirst selection set
    ObjectId[] idarrayEmpty = new ObjectId[0];
    acDocEd.SetImpliedSelection(idarrayEmpty);
    // Request for objects to be selected in the drawing area
    acSSPrompt = acDocEd.GetSelection();
        Application.ShowAlertDialog("Number of objects selected: " +
    else
        Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考
    ' Get the Pickfirst selection set
    Dim acSSet As AcadSelectionSet
    Set acSSet = ThisDrawing.PickfirstSelectionSet
    ' Display the number of selected objects
    MsgBox "Number of objects in Pickfirst selection set: " & acSSet.Count
    ' Create a new selection set
    Dim acSSetUser As AcadSelectionSet
    Set acSSetUser = ThisDrawing.SelectionSets.Add("User")
    ' Select objects in the drawing
    acSSetUser.SelectOnScreen
    MsgBox "Number of objects selected: " & acSSetUser.Count
    ' Remove the new named selection set
    acSSetUser.Delete
GMT+8, 2026-11-15 12:13
