创建样条对象 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 738| 评论: 0|原作者: admin|来自: AutoCAD
创建样条对象 (.NET)
此示例使用三个点 (0, 0, 0)、(5, 5, 0) 和 (10, 0, 0) 在模型空间中创建一个圆。样条的起点和终点切线为 (0.5, 0.5, 0.0)。
VB.NET
<CommandMethod("AddSpline")> _
Public Sub AddSpline()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Define the fit points for the spline
        Dim ptColl As Point3dCollection = New Point3dCollection()
        ptColl.Add(New Point3d(0, 0, 0))
        ptColl.Add(New Point3d(5, 5, 0))
        ptColl.Add(New Point3d(10, 0, 0))
        '' Get a 3D vector from the point (0.5,0.5,0)
        Dim vecTan As Vector3d = New Point3d(0.5, 0.5, 0).GetAsVector
        '' Create a spline through (0, 0, 0), (5, 5, 0), and (10, 0, 0) with a
        '' start and end tangency of (0.5, 0.5, 0.0)
        Using acSpline As Spline = New Spline(ptColl, vecTan, vecTan, 4, 0.0)
            acBlkTblRec.AppendEntity(acSpline)
            acTrans.AddNewlyCreatedDBObject(acSpline, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddSpline")]
public static void AddSpline()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Define the fit points for the spline
        Point3dCollection ptColl = new Point3dCollection();
        ptColl.Add(new Point3d(0, 0, 0));
        ptColl.Add(new Point3d(5, 5, 0));
        ptColl.Add(new Point3d(10, 0, 0));
        // Get a 3D vector from the point (0.5,0.5,0)
        Vector3d vecTan = new Point3d(0.5, 0.5, 0).GetAsVector();
        // Create a spline through (0, 0, 0), (5, 5, 0), and (10, 0, 0) with a
        // start and end tangency of (0.5, 0.5, 0.0)
        using (Spline acSpline = new Spline(ptColl, vecTan, vecTan, 4, 0.0))
            acBlkTblRec.AppendEntity(acSpline);
            acTrans.AddNewlyCreatedDBObject(acSpline, true);
        // Save the new line to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddSpline()
    ' This example creates a spline object in model space.
    ' Declare the variables needed
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    ' Define the variables
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create the spline
    Set splineObj = ThisDrawing.ModelSpace.AddSpline _
                        (fitPoints, startTan, endTan)
    ZoomAll
GMT+8, 2026-10-27 09:19
