创建 Arc 对象 (.NET)
本示例在模型空间中创建一个圆弧,其中心点为 (6.25,9.125,0),半径为 6,起始角为 1.117(64 度),结束角为 3.5605(204 度)。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddArc")> _
Public Sub AddArc()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create an arc that is at 6.25,9.125 with a radius of 6, and
'' starts at 64 degrees and ends at 204 degrees
Using acArc As Arc = New Arc(New Point3d(6.25, 9.125, 0), _
6, 1.117, 3.5605)
acBlkTblRec.AppendEntity(acArc)
acTrans.AddNewlyCreatedDBObject(acArc, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddArc")]
public static void AddArc()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create an arc that is at 6.25,9.125 with a radius of 6, and
// starts at 64 degrees and ends at 204 degrees
using (Arc acArc = new Arc(new Point3d(6.25, 9.125, 0),
6, 1.117, 3.5605))
acBlkTblRec.AppendEntity(acArc);
acTrans.AddNewlyCreatedDBObject(acArc, true);
// Save the new line to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddArc()
' Define the center point
Dim ptCen(0 To 2) As Double
ptCen(0) = 6.25: ptCen(1) = 9.125: ptCen(2) = 0#
' Create an Arc object in model space
Dim arcObj As AcadArc
Set arcObj = ThisDrawing.ModelSpace.AddArc(ptCen, 6#, 1.117, 3.5605)
相关概念父主题: |
GMT+8, 2026-10-28 04:53
