创建 Circle 对象 (.NET)
本示例在模型空间中创建一个中心点为 (2,3,0) 且半径为 4.25 的圆。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddCircle")> _
Public Sub AddCircle()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle that is at 2,3 with a radius of 4.25
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 3, 0)
acCirc.Radius = 4.25
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddCircle")]
public static void AddCircle()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle that is at 2,3 with a radius of 4.25
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 3, 0);
acCirc.Radius = 4.25;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddCircle()
' Define the center point
Dim ptCen(0 To 2) As Double
ptCen(0) = 2: ptCen(1) = 3: ptCen(2) = 0#
' Create a Circle object in model space
Dim circObj As AcadCircle
Set circObj = ThisDrawing.ModelSpace.AddCircle(ptCen, 4.25)
相关概念父主题: |
GMT+8, 2026-10-27 09:03
