确定父对象 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 761| 评论: 0|原作者: admin|来自: AutoCAD
确定父对象 (.NET)
图形对象将追加到对象,例如“模型”或“图纸空间”。您可以通过对象引用表示 Model 和 Paper 空间的块。如果要在当前空间而不是特定空间中工作,请从具有该属性的当前数据库中获取当前空间的 ObjectId。BlockTableRecordBlockTableCurrentSpaceId
可以使用命名空间下类的属性或 and 方法从对象中检索 Model 和 Paper 空间的块表记录的 ObjectId。BlockTableGetBlockModelSpaceIdGetBlockPaperSpaceIdSymbolUtilityServicesDatabaseServices
访问模型空间、图纸空间或当前空间
以下示例演示如何访问与模型空间、图纸空间或当前空间关联的块表记录。引用块表记录后,将向块表记录添加新行。
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("AccessSpace")> _
Public Sub AccessSpace()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
        '' Open the Block table record for read
        '' Request which table record to open
        Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("")
        pKeyOpts.Message = vbLf & "Enter which space to create the line in "
        pKeyOpts.Keywords.Add("Model")
        pKeyOpts.Keywords.Add("Paper")
        pKeyOpts.Keywords.Add("Current")
        pKeyOpts.AllowNone = False
        pKeyOpts.AppendKeywordsToMessage = True
        Dim pKeyRes As PromptResult = acDoc.Editor.GetKeywords(pKeyOpts)
        If pKeyRes.StringResult = "Model" Then
            '' Get the ObjectID for Model space from the Block table
                                            OpenMode.ForWrite)
        ElseIf pKeyRes.StringResult = "Paper" Then
            '' Get the ObjectID for Paper space from the Block table
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _
                                            OpenMode.ForWrite)
        Else
            '' Get the ObjectID for the current space from the database
            acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, _
                                            OpenMode.ForWrite)
        End If
        '' Create a line that starts at 2,5 and ends at 10,7
        Using acLine As Line = New Line(New Point3d(2, 5, 0), _
                                        New Point3d(10, 7, 0))
            acBlkTblRec.AppendEntity(acLine)
            acTrans.AddNewlyCreatedDBObject(acLine, True)
        End Using
        '' Save the new line to the database
        acTrans.Commit()
    End Using
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("AccessSpace")]
public static void AccessSpace()
    // Start a transaction
        BlockTable acBlkTbl;
        // Open the Block table record for read
        BlockTableRecord acBlkTblRec;
        // Request which table record to open
        PromptKeywordOptions pKeyOpts = new PromptKeywordOptions("");
        pKeyOpts.Message = "\nEnter which space to create the line in ";
        pKeyOpts.Keywords.Add("Model");
        pKeyOpts.Keywords.Add("Paper");
        pKeyOpts.Keywords.Add("Current");
        pKeyOpts.AllowNone = false;
        pKeyOpts.AppendKeywordsToMessage = true;
        PromptResult pKeyRes = acDoc.Editor.GetKeywords(pKeyOpts);
        if (pKeyRes.StringResult == "Model")
            // Get the ObjectID for Model space from the Block table
        else if (pKeyRes.StringResult == "Paper")
            // Get the ObjectID for Paper space from the Block table
            acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace],
        else
            // Get the ObjectID for the current space from the database
        // Create a line that starts at 2,5 and ends at 10,7
        using (Line acLine = new Line(new Point3d(2, 5, 0),
                                new Point3d(10, 7, 0)))
            acBlkTblRec.AppendEntity(acLine);
            acTrans.AddNewlyCreatedDBObject(acLine, true);
        // Save the new line to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Define the valid keywords
    Dim keywordList As String
    keywordList = "Model Paper Current"
    ' Call InitializeUserInput to setup the keywords
    ThisDrawing.Utility.InitializeUserInput 1, keywordList
    ' Get the user input
    Dim retVal As Variant
    retVal = ThisDrawing.Utility.GetKeyword(vbLf & _
                                   "Enter which space to create the line in " & _
                                   "[Model/Paper/Current]: ")
    ' Get the entered keyword
    Dim strVal As String
    strVal = ThisDrawing.Utility.GetInput
    Dim acSpaceObj As Object
    If strVal = "Model" Or _
      (strVal = "Current" And ThisDrawing.ActiveSpace = acModelSpace) Then
        '' Get the Model space object
        Set acSpaceObj = ThisDrawing.ModelSpace
    Else
        '' Get the Paper space object
        Set acSpaceObj = ThisDrawing.PaperSpace
    End If
    Dim acLine As AcadLine
    Dim dPtStr(0 To 2) As Double
    dPtStr(0) = 2: dPtStr(1) = 5: dPtStr(2) = 0#
    Dim dPtEnd(0 To 2) As Double
    dPtEnd(0) = 10: dPtEnd(1) = 7: dPtEnd(2) = 0#
    Set acLine = acSpaceObj.AddLine(dPtStr, dPtEnd)
GMT+8, 2026-10-27 05:15
