计算定义区域 (.NET)
如果要计算的面积基于用户指定的点,则可以考虑在内存中创建一个对象,例如轻量级折线,然后在丢弃对象之前查询该对象的面积。以下步骤说明如何实现此目的:
计算由用户输入的点定义的区域本示例提示用户输入 5 个点。然后,从输入的点中创建折线。折线是闭合的,折线的面积显示在消息框中。由于折线未添加到块中,因此需要在命令结束之前对其进行处置。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("CalculateDefinedArea")> _
Public Sub CalculateDefinedArea()
'' Prompt the user for 5 points
Dim pPtRes As PromptPointResult
Dim colPt As Point2dCollection = New Point2dCollection
Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
'' Prompt for the first point
pPtOpts.Message = vbLf & "Specify first point: "
pPtRes = acDoc.Editor.GetPoint(pPtOpts)
colPt.Add(New Point2d(pPtRes.Value.X, pPtRes.Value.Y))
'' Exit if the user presses ESC or cancels the command
If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
Dim nCounter As Integer = 1
While (nCounter <= 4)
'' Prompt for the next points
Select Case nCounter
Case 1
pPtOpts.Message = vbLf & "Specify second point: "
Case 2
pPtOpts.Message = vbLf & "Specify third point: "
Case 3
pPtOpts.Message = vbLf & "Specify fourth point: "
Case 4
pPtOpts.Message = vbLf & "Specify fifth point: "
End Select
'' Use the previous point as the base point
pPtOpts.UseBasePoint = True
pPtOpts.BasePoint = pPtRes.Value
'' Increment the counter
nCounter = nCounter + 1
End While
'' Create a polyline with 5 points
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, colPt(0), 0, 0, 0)
acPoly.AddVertexAt(1, colPt(1), 0, 0, 0)
acPoly.AddVertexAt(2, colPt(2), 0, 0, 0)
acPoly.AddVertexAt(3, colPt(3), 0, 0, 0)
acPoly.AddVertexAt(4, colPt(4), 0, 0, 0)
'' Close the polyline
acPoly.Closed = True
'' Query the area of the polyline
Application.ShowAlertDialog("Area of polyline: " & _
acPoly.Area.ToString())
'' Dispose of the polyline
End Using
C#using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("CalculateDefinedArea")]
public static void CalculateDefinedArea()
// Prompt the user for 5 points
PromptPointResult pPtRes;
Point2dCollection colPt = new Point2dCollection();
PromptPointOptions pPtOpts = new PromptPointOptions("");
// Prompt for the first point
pPtOpts.Message = "\nSpecify first point: ";
pPtRes = acDoc.Editor.GetPoint(pPtOpts);
colPt.Add(new Point2d(pPtRes.Value.X, pPtRes.Value.Y));
// Exit if the user presses ESC or cancels the command
if (pPtRes.Status == PromptStatus.Cancel) return;
int nCounter = 1;
while (nCounter <= 4)
// Prompt for the next points
switch(nCounter)
case 1:
pPtOpts.Message = "\nSpecify second point: ";
break;
case 2:
pPtOpts.Message = "\nSpecify third point: ";
break;
case 3:
pPtOpts.Message = "\nSpecify fourth point: ";
break;
case 4:
pPtOpts.Message = "\nSpecify fifth point: ";
break;
// Use the previous point as the base point
pPtOpts.UseBasePoint = true;
pPtOpts.BasePoint = pPtRes.Value;
// Increment the counter
nCounter = nCounter + 1;
// Create a polyline with 5 points
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, colPt[0], 0, 0, 0);
acPoly.AddVertexAt(1, colPt[1], 0, 0, 0);
acPoly.AddVertexAt(2, colPt[2], 0, 0, 0);
acPoly.AddVertexAt(3, colPt[3], 0, 0, 0);
acPoly.AddVertexAt(4, colPt[4], 0, 0, 0);
// Close the polyline
acPoly.Closed = true;
// Query the area of the polyline
Application.ShowAlertDialog("Area of polyline: " +
acPoly.Area.ToString());
// Dispose of the polyline
VBA/ActiveX 代码参考本示例提示用户输入 5 个点。然后,从输入的点中创建折线。折线是闭合的,折线的面积显示在消息框中。与 AutoCAD .NET API 示例不同,折线不是在内存中创建的,而是作为数据库驻留对象创建并添加到模型空间中。因此,在获得折线的面积后,将其删除。 Sub CalculateDefinedArea()
Dim p1 As Variant
Dim p2 As Variant
Dim p3 As Variant
Dim p4 As Variant
Dim p5 As Variant
' Get the points from the user
p1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "Specify first point: ")
p2 = ThisDrawing.Utility.GetPoint(p1, vbCrLf & "Specify second point: ")
p3 = ThisDrawing.Utility.GetPoint(p2, vbCrLf & "Specify third point: ")
p4 = ThisDrawing.Utility.GetPoint(p3, vbCrLf & "Specify fourth point: ")
p5 = ThisDrawing.Utility.GetPoint(p4, vbCrLf & "Specify fifth point: ")
' Create the 2D polyline from the points
Dim polyObj As AcadLWPolyline
Dim vertices(0 To 9) As Double
vertices(0) = p1(0): vertices(1) = p1(1)
vertices(2) = p2(0): vertices(3) = p2(1)
vertices(4) = p3(0): vertices(5) = p3(1)
vertices(6) = p4(0): vertices(7) = p4(1)
vertices(8) = p5(0): vertices(9) = p5(1)
Set polyObj = ThisDrawing.ModelSpace.AddLightWeightPolyline _
(vertices)
polyObj.Closed = True
' Display the area for the polyline
MsgBox "The area defined by the points is " & _
polyObj.Area, , "Calculate Defined Area"
' Remove the polyline
polyObj.Delete
相关概念父主题: |
GMT+8, 2026-10-27 12:17
