创建和打开图形 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 1017| 评论: 0|原作者: admin|来自: AutoCAD
创建和打开图形 (.NET)
若要创建新图形或打开现有图形,请使用对象的方法。该方法基于图形样板创建新的图形文件,并将该图形添加到 .该方法将打开现有图形文件。DocumentCollectionExtensionAddDocumentCollectionExtensionOpen
创建新图形
本示例使用该方法基于 acad.dwt 图形样板文件创建新图形。Add
VB.NET
<CommandMethod("NewDrawing", CommandFlags.Session)> _
Public Sub NewDrawing()
    '' Specify the template to use, if the template is not found
    '' the default settings are used.
    Dim strTemplatePath As String = "acad.dwt"
    Dim acDocMgr As DocumentCollection = Application.DocumentManager
    Dim acDoc As Document = DocumentCollectionExtension.Add(acDocMgr, strTemplatePath)
    acDocMgr.MdiActiveDocument = acDoc
C#
[CommandMethod("NewDrawing", CommandFlags.Session)]
public static void NewDrawing()
    // Specify the template to use, if the template is not found
    // the default settings are used.
    string strTemplatePath = "acad.dwt";
    DocumentCollection acDocMgr = Application.DocumentManager;
    Document acDoc = acDocMgr.Add(strTemplatePath);
    acDocMgr.MdiActiveDocument = acDoc;
VBA/ActiveX 代码参考
Sub NewDrawing()
    Dim docObj As AcadDocument
    Set docObj = ThisDrawing.Application.Documents.Add(strTemplatePath)
打开现有图形
本示例使用该方法打开现有图形。在打开图形之前,代码会在尝试打开文件之前检查文件是否存在。Open
VB.NET
Imports System.IO
<CommandMethod("OpenDrawing", CommandFlags.Session)> _
Public Sub OpenDrawing()
    Dim strFileName As String = "C:\campus.dwg"
    If (File.Exists(strFileName)) Then
        DocumentCollectionExtension.Open(acDocMgr, strFileName, False)
    Else
        acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strFileName & _
                                                       " does not exist.")
    End If
C#
using System.IO;
[CommandMethod("OpenDrawing", CommandFlags.Session)]
public static void OpenDrawing()
    string strFileName = "C:\\campus.dwg";
    if (File.Exists(strFileName))
        acDocMgr.Open(strFileName, false);
    else
        acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + strFileName +
                                                        " does not exist.");
VBA/ActiveX 代码参考
Sub OpenDrawing()
    Dim dwgName As String
    dwgName = "c:\campus.dwg"
    If Dir(dwgName) <> "" Then
        ThisDrawing.Application.Documents.Open dwgName
    Else
        MsgBox "File " & dwgName & " does not exist."
    End If
GMT+8, 2026-11-4 22:10
