使平铺视口成为当前 (.NET)
在当前视口中输入点并选择对象。要使视口成为当前视口,请使用 CVPORT 系统变量,并按要设置为当前的视口编号指定视口。 您可以循环访问现有视口以查找特定视口。为此,请使用该属性标识名称为“*Active”的视口表记录。Name 拆分视口,然后遍历窗口本示例将活动视口拆分为两个水平窗口。然后,它会循环访问图形中所有平铺的视口,并显示视口名称以及每个视口的左下角和右上角。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
<CommandMethod("SplitAndIterateModelViewports")> _
Public Sub SplitAndIterateModelViewports()
'' Get the current database
'' Start a transaction
'' Open the Viewport table for write
Dim acVportTbl As ViewportTable
acVportTbl = acTrans.GetObject(acCurDb.ViewportTableId, _
OpenMode.ForWrite)
'' Open the active viewport for write
Dim acVportTblRec As ViewportTableRecord
acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, _
OpenMode.ForWrite)
Using acVportTblRecNew As ViewportTableRecord = New ViewportTableRecord()
'' Add the new viewport to the Viewport table and the transaction
acVportTbl.Add(acVportTblRecNew)
acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, True)
'' Assign the name '*Active' to the new Viewport
acVportTblRecNew.Name = "*Active"
'' Use the existing lower left corner for the new viewport
acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner
'' Get half the X of the existing upper corner
acVportTblRecNew.UpperRightCorner = New Point2d(acVportTblRec.UpperRightCorner.X, _
acVportTblRec.LowerLeftCorner.Y + _
((acVportTblRec.UpperRightCorner.Y - _
acVportTblRec.LowerLeftCorner.Y) / 2))
'' Recalculate the corner of the active viewport
acVportTblRec.LowerLeftCorner = New Point2d(acVportTblRec.LowerLeftCorner.X, _
acVportTblRecNew.UpperRightCorner.Y)
'' Update the display with the new tiled viewports arrangement
acDoc.Editor.UpdateTiledViewportsFromDatabase()
'' Step through each object in the symbol table
For Each acObjId As ObjectId In acVportTbl
'' Open the object for read
Dim acVportTblRecCur As ViewportTableRecord
acVportTblRecCur = acTrans.GetObject(acObjId, _
OpenMode.ForRead)
If (acVportTblRecCur.Name = "*Active") Then
Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number)
Application.ShowAlertDialog("Viewport: " & acVportTblRecCur.Number & _
" is now active." & _
vbLf & "Lower left corner: " & _
acVportTblRecCur.LowerLeftCorner.X & ", " & _
acVportTblRecCur.LowerLeftCorner.Y & _
vbLf & "Upper right corner: " & _
acVportTblRecCur.UpperRightCorner.X & ", " & _
acVportTblRecCur.UpperRightCorner.Y)
End If
Next
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
C#using Autodesk.AutoCAD.ApplicationServices;
[CommandMethod("SplitAndIterateModelViewports")]
public static void SplitAndIterateModelViewports()
// Get the current database
// Start a transaction
// Open the Viewport table for write
ViewportTable acVportTbl;
OpenMode.ForWrite) as ViewportTable;
// Open the active viewport for write
ViewportTableRecord acVportTblRec;
OpenMode.ForWrite) as ViewportTableRecord;
using (ViewportTableRecord acVportTblRecNew = new ViewportTableRecord())
// Add the new viewport to the Viewport table and the transaction
acVportTbl.Add(acVportTblRecNew);
acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, true);
// Assign the name '*Active' to the new Viewport
acVportTblRecNew.Name = "*Active";
// Use the existing lower left corner for the new viewport
acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner;
// Get half the X of the existing upper corner
acVportTblRecNew.UpperRightCorner = new Point2d(acVportTblRec.UpperRightCorner.X,
acVportTblRec.LowerLeftCorner.Y) / 2));
// Recalculate the corner of the active viewport
acVportTblRec.LowerLeftCorner = new Point2d(acVportTblRec.LowerLeftCorner.X,
acVportTblRecNew.UpperRightCorner.Y);
// Update the display with the new tiled viewports arrangement
acDoc.Editor.UpdateTiledViewportsFromDatabase();
// Step through each object in the symbol table
foreach (ObjectId acObjId in acVportTbl)
// Open the object for read
ViewportTableRecord acVportTblRecCur;
OpenMode.ForRead) as ViewportTableRecord;
if (acVportTblRecCur.Name == "*Active")
Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number);
Application.ShowAlertDialog("Viewport: " + acVportTblRecCur.Number +
" is now active." +
"\nLower left corner: " +
acVportTblRecCur.LowerLeftCorner.X + ", " +
acVportTblRecCur.LowerLeftCorner.Y +
"\nUpper right corner: " +
acVportTblRecCur.UpperRightCorner.X + ", " +
acVportTblRecCur.UpperRightCorner.Y);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub SplitandInterateModelViewports()
' Get the active viewport
Dim vportObj As AcadViewport
Set vportObj = ThisDrawing.ActiveViewport
' Split the viewport into 2 windows
vportObj.Split acViewport2Horizontal
' Iterate through the viewports,
' highlighting each viewport and displaying
' the upper right and lower left corners
' for each.
Dim vport As AcadViewport
Dim LLCorner As Variant
Dim URCorner As Variant
For Each vport In ThisDrawing.Viewports
ThisDrawing.ActiveViewport = vport
LLCorner = vport.LowerLeftCorner
URCorner = vport.UpperRightCorner
MsgBox "Viewport: " & vport.Name & " is now active." & _
vbCrLf & "Lower left corner: " & _
LLCorner(0) & ", " & LLCorner(1) & vbCrLf & _
URCorner(0) & ", " & URCorner(1)
Next vport
相关概念父主题: |
GMT+8, 2026-10-27 01:21
