练习:创建新命令 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 924| 评论: 0|原作者: admin|来自: AutoCAD
练习:创建新命令 (.NET)
现在,您已经创建了一个项目并添加了必要的库引用,是时候创建命令了。该命令将在模型空间中创建一个新的多行文本 (MText) 对象。这些概念和其他概念将在后面的章节中深入讨论。
定义创建新 MText 对象的新命令
  1. 在“解决方案资源管理器”中,双击“Class1.vb”或“Class1.cs”,具体取决于您创建的项目类型。
    将打开 Class1 模块的代码窗口,它应如下所示:
    VB.NET
    Public Class Class1
    End Class
    C#
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    namespace MyFirstProject1
      public class Class1
  2. 更改代码窗口中的代码以匹配以下内容:
    VB.NET
    Public Class Class1
      <CommandMethod("AdskGreeting")> _
      Public Sub AdskGreeting()
          '' Get the current document and database, and start a transaction
              '' Open the Block table record for read
              Dim acBlkTbl As BlockTable
                                           OpenMode.ForRead)
                                              OpenMode.ForWrite)
              '' Creates a new MText object and assigns it a location,
              '' text value and text style
              Using objText As MText = New MText
                  '' Specify the insertion point of the MText object
                  objText.Location = New Autodesk.AutoCAD.Geometry.Point3d(2, 2, 0)
                  '' Set the text string for the MText object
                  objText.Contents = "Greetings, Welcome to AutoCAD .NET"
                  '' Set the text style for the MText object
                  objText.TextStyleId = acCurDb.Textstyle
                  '' Appends the new MText object to model space
                  acBlkTblRec.AppendEntity(objText)
                  '' Appends to new MText object to the active transaction
                  acTrans.AddNewlyCreatedDBObject(objText, True)
              End Using
              '' Saves the changes to the database and closes the transaction
              acTrans.Commit()
          End Using
    End Class
    C#
    using System;
    using System.Linq;
    using System.Text;
    [assembly: CommandClass(typeof(MyFirstProject1.Class1))]
      public class Class1
          [CommandMethod("AdskGreeting")]
          public void AdskGreeting()
              // Get the current document and database, and start a transaction
              // Starts a new transaction with the Transaction Manager
                  // Open the Block table record for read
                  BlockTable acBlkTbl;
                  BlockTableRecord acBlkTblRec;
                  /* Creates a new MText object and assigns it a location,
                  text value and text style */
                  using (MText objText = new MText())
                      // Specify the insertion point of the MText object
                      objText.Location = new Autodesk.AutoCAD.Geometry.Point3d(2, 2, 0);
                      // Set the text string for the MText object
                      objText.Contents = "Greetings, Welcome to AutoCAD .NET";
                      // Set the text style for the MText object
                      objText.TextStyleId = acCurDb.Textstyle;
                      // Appends the new MText object to model space
                      acBlkTblRec.AppendEntity(objText);
                      // Appends to new MText object to the active transaction
                      acTrans.AddNewlyCreatedDBObject(objText, true);
                  // Saves the changes to the database and closes the transaction
                  acTrans.Commit();
GMT+8, 2026-10-27 09:45
