VisualFidelity 属性 (ActiveX/ATO)
2024-5-18 16:57| 发布者: admin| 查看: 491| 评论: 0|原作者: admin|来自: AutoCAD
指定是否为保存为 AutoCAD 2007 及更早版本文件格式的图形保持注释对象的视觉保真度。
命名空间:传输塔利布
集会:AcETransmit19.tlb
VBA/VB.NET/C#:
object.visualFidelity
类型:TransmittalInfo
此属性应用于的对象。
只读:不
类型:长
  • 0 (False) - 注释对象保留在其分配的图层上。
  • 1 (True) - 对于使用的每个比例,分配了注释比例的注释对象将保存到单独的图层中。
发行信息
释放:AutoCAD 2008 及更高版本
  • AcETransmit19.tlb - AutoCAD 2015 及更高版本
  • AcETransmit18.tlb - AutoCAD 2010 到 AutoCAD 2014
    • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalInfo3ITransmittalInfo
  • AcETransmit16.tlb - AutoCAD 2008 到 AutoCAD 2009
    • 该特性是在 AutoCAD 2008 版本的库中引入的。dataLinkRelativePathITransmittalInfo3
VB.NET:
' Custom function used to setup a TransmittalInfo object
Private Shared Function TransInfo(ti As TransmittalInfo, destination As String) _
    As TransmittalInfo
    ' Specify the folder that the files should be copied to
    If System.IO.Directory.Exists(destination) = False Then
        System.IO.Directory.CreateDirectory(destination)
    End If
    ' Assign the location which the transmittal package should be stored
    ti.destinationRoot = destination
    ' Maintain sub directories (0 - False, 1 - True)
    ti.preserveSubdirs = vbTrue
    ' Maintain folder paths
    ' ti.organizedFolder = 0 and ti.preserveSubdirs = 0 -
    '             All files are placed in a single folder which is specified
    '             by the destinationRoot property
    ' ti.organizedFolder = 1 and ti.preserveSubdirs = 0 -
    '             Files are placed in a single folder, but maintain one level
    '             of subdirectory strcuture
    ' ti.organizedFolder = 0 and ti.preserveSubdirs = 1 -
    '             Folder structure is maintained, but the paths for
    '             reference files are not
    ' ti.organizedFolder = 1 and ti.preserveSubdirs = 1 -
    '             Folder structure and reference paths are maintained
    ti.organizedFolder = vbTrue
    ' Change referenced files to use relative paths (0 - False, 1 - True)
    ti.dataLinkRelativePath = vbTrue
    ti.DGNUnderlayRelativePath = vbTrue
    ti.DWFUnderlayRelativePath = vbTrue
    ti.imageRelativePath = vbTrue
    ti.PDFUnderlayRelativePath = vbTrue
    ti.xrefRelativePath = vbTrue
    ' Set the default drawing file format for all DWG, DWT, and DWS files
    ' SaveDwgFormat.eAutoCAD14 - AutoCAD R14
    ' SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000
    ' SaveDwgFormat.eAutoCADR18 - AutoCAD 2004
    ' SaveDwgFormat.eAutoCADR21 - AutoCAD 2007
    ' SaveDwgFormat.eAutoCADR24 - AutoCAD 2010
    ' SaveDwgFormat.eAutoCADR27 - AutoCAD 2013
    ' SaveDwgFormat.eNoConversion - Keep current format
    ti.saveVersion = SaveDwgFormat.eNoConversion
    ' Maintain visual fidelity (SAVEFIDELITY system variable)
    ' 0 - Saved without visual fidelity
    ' 1 - Annotation objects assigned annotative scales are saved to
    '     separate layers for each scale used.
    '     Only affects drawings when saving to AutoCAD 2007 or earlier file formats.
    ti.visualFidelity = vbTrue
    ' Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
    ti.includeXrefDwg = vbTrue
    ti.includeUnloadedReferences = vbTrue
    ti.includeUnloadedXrefDwg = vbTrue
    ti.includeNestedOverlayXrefDwg = vbTrue
    ' Bind xrefs attached to a drawing (0 - False, 1 - True)
    ' BindType.eBind - Use the Bind type to bind the xrefs
    ' BindType.eInsert - Use the Insert type to bind the xrefs
    ti.BindType = BindType.eInsert
    ' Remove paths from xrefs (0 - False, 1 - True)
    ti.depathXrefs = vbTrue
    ' Include images, underlays, and datalink file (0 - False, 1 - True)
    ti.includeImageFile = vbTrue
    ti.includeDGNUnderlay = vbTrue
    ti.includeDWFUnderlay = vbTrue
    ti.includePDFUnderlay = vbTrue
    ti.includeDataLinkFile = vbTrue
    ' Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
    ti.includeFontFile = vbTrue
    ' Reset plotters for layouts in the drawings to None,
    ' and include plot style (CTB/STB) files (0 - False, 1 - True)
    ti.resetPlotter = vbFalse
    ti.includePlotFile = vbTrue
    ' Specify where the plot files are located so the API can resolve the file
    ' paths (used when includePlotFile = vbTrue or 1)
    ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + _
             "\AppData\Roaming\Autodesk\AutoCAD 2016\R20.1\enu\Plotters"
    ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + _
             "\AppData\Roaming\Autodesk\AutoCAD 2016\R20.1\enu\Plotters\Plot Styles"
    ' Get the photometric Web and material files used by lights
    ' and 3D objects for rendering (0 - False, 1 - True)
    ti.includePhotometricWebFile = vbTrue
    ti.includeMaterialTextureFile = vbTrue
    ' Purge unused named objects for all drawing files in the
    ' Transmittal(Package(0 - False, 1 - True))
    ti.purgeDatabase = vbFalse
    Return ti
End Function
C#:
// Custom function used to setup a TransmittalInfo object
private static TransmittalInfo TransInfo(TransmittalInfo ti, string destination)
    // Specify the folder that the files should be copied to
    if (System.IO.Directory.Exists(destination) == false)
        System.IO.Directory.CreateDirectory(destination);
    // Assign the location which the transmittal package should be stored
    ti.destinationRoot = destination;
    // Maintain sub directories (0 - False, 1 - True)
    ti.preserveSubdirs = 1;
    ti.organizedFolder = 1;
    // Change referenced files to use relative paths (0 - False, 1 - True)
    ti.dataLinkRelativePath = 1;
    ti.DGNUnderlayRelativePath = 1;
    ti.DWFUnderlayRelativePath = 1;
    ti.imageRelativePath = 1;
    ti.PDFUnderlayRelativePath = 1;
    ti.xrefRelativePath = 1;
    /* Set the default drawing file format for all DWG, DWT, and DWS files
    ti.saveVersion = SaveDwgFormat.eNoConversion;
    ti.visualFidelity = 1;
    // Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
    ti.includeXrefDwg = 1;
    ti.includeUnloadedReferences = 1;
    ti.includeUnloadedXrefDwg = 1;
    ti.includeNestedOverlayXrefDwg = 1;
    ti.BindType = BindType.eInsert;
    // Remove paths from xrefs (0 - False, 1 - True)
    ti.depathXrefs = 1;
    // Include images, underlays, and datalink file (0 - False, 1 - True)
    ti.includeImageFile = 1;
    ti.includeDGNUnderlay = 1;
    ti.includeDWFUnderlay = 1;
    ti.includePDFUnderlay = 1;
    ti.includeDataLinkFile = 1;
    // Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
    ti.includeFontFile = 1;
    // Reset plotters for layouts in the drawings to None,
    // and include plot style (CTB/STB) files (0 - False, 1 - True)
    ti.resetPlotter = 0;
    ti.includePlotFile = 1;
    // Specify where the plot files are located so the API can resolve the file
    // paths (used when includePlotFile = True or 1)
                            "\\AppData\\Roaming\\Autodesk\\AutoCAD 2016\\R20.1\\enu\\Plotters";
                            "\\AppData\\Roaming\\Autodesk\\AutoCAD 2016\\R20.1\\enu\\Plotters\\Plot Styles";
    // Get the photometric Web and material files used by lights
    // and 3D objects for rendering (0 - False, 1 - True)
    ti.includePhotometricWebFile = 1;
    ti.includeMaterialTextureFile = 1;
    // Purge unused named objects for all drawing files in the
    // Transmittal(Package(0 - False, 1 - True))
    ti.purgeDatabase = 0;
    return ti;
GMT+8, 2026-11-3 20:56
