SetProgressMeter 方法 (ActiveX/ATO)
注册传递集的进度处理程序。 支持的平台:仅限 Windows 命名空间:传输塔利布 集会:AcETransmit19.tlb 签名VB.NET: object.setProgressMeter(meter, add) C#: object.setProgressMeter(meter, add);
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本
例子VB.NET: ' Custom command to create a transmittal package from a sheet set
<CommandMethod("eTransmitDSTFile")> _
Public Shared Sub eTransmitDSTFile()
Dim ti As TransmittalInfo = _
TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
' Add a file notification handler
Dim fileHandler As New MyTransFileNotifier
tro.subscribeToAddFileNotification(fileHandler)
' Setup the progress meter for use with sheet selection sets, _
' sheet sets, and the creation of a transmittal package
Dim pmHandler As New MyProgressHandler
tro.setProgressMeter(pmHandler, 1)
' Add a sheet set and the drawings referenced in it
' Get a reference to the Sheet Set Manager object
Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr
' Open a sheet set (DST) file
Dim sheetSetDatabase As AcSmDatabase = _
sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False)
' Get the sheet set from the database and process it
' 0 - Do not include DST file or support files referenced
' by the DST file (templates, blocks, ...)
' 1 - Include DST file, all files referenced by the DST file,
' its(sheets And references)
tro.archiveSheetSet(sheetSetDatabase.GetSheetSet(), vbTrue)
' Close the sheet set
sheetSetManager.Close(sheetSetDatabase)
' Remove the file notification handler
tro.cancelSubscriptionToAddFileNotification(fileHandler)
' Remove the progress meter handler
pmHandler = Nothing
' Create the transmittal package
' Files are copied and resaved to the path specified by the destinationRoot property
' and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage()
C#: // Custom command to create a transmittal package from a sheet set
[CommandMethod("eTransmitDSTFile")]
public static void eTransmitDSTFile()
TransmittalInfo ti =
TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
// Add a file notification handler
MyTransFileNotifier fileHandler = new MyTransFileNotifier();
tro.subscribeToAddFileNotification(fileHandler);
// Setup the progress meter for use with sheet selection sets, _
// sheet sets, and the creation of a transmittal package
MyProgressHandler pmHandler = new MyProgressHandler();
tro.setProgressMeter(pmHandler, 1);
// Add a sheet set and the drawings referenced in it
// Get a reference to the Sheet Set Manager object
IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
// Open a sheet set (DST) file
AcSmDatabase sheetSetDatabase =
sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false);
// Get the sheet set from the database and process it
// 0 - Do not include DST file or support files referenced
// by the DST file (templates, blocks, ...)
// 1 - Include DST file, all files referenced by the DST file,
// its(sheets And references)
tro.archiveSheetSet(sheetSetDatabase.GetSheetSet(), 1);
// Close the sheet set
sheetSetManager.Close(sheetSetDatabase);
// Remove the file notification handler
tro.cancelSubscriptionToAddFileNotification(fileHandler);
// Remove the progress meter handler
pmHandler = null;
// Create the transmittal package
// Files are copied and resaved to the path specified by the destinationRoot property
// and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage();
相关参考 |
GMT+8, 2026-11-3 20:56
