PreDatabaseProcessing 方法 (ActiveX/ATO)
在处理数据库之前触发。 支持的平台:仅限 Windows 命名空间:传输塔利布 集会:AcETransmit19.tlb 签名VB.NET: Friend Class custom_class_name
Implements TransmittalDatabaseNotificationHandler
Public Function preDatabaseProcessing(pDatabase As Object, _
pFile As TransmittalFile, _
pTransmit As TransmittalOperation) _
As Integer _
Implements ITransmittalDatabaseNotificationHandler.preDatabaseProcessing
End Function
End Class
C#: internal class custom_class_name : TransmittalDatabaseNotificationHandler
public int preDatabaseProcessing(object pDatabase,
TransmittalFile pFile,
TransmittalOperation pTransmit)
return RetVal;
返回值 (RetVal)类型:长
言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本
例子VB.NET: ' Custom class used to monitor the processing of a drawing
Friend Class MyTransDbNotifier
pFile As TRANSMITTALLib.TransmittalFile, _
pTransmit As TRANSMITTALLib.TransmittalOperation) _
As Integer _
Implements TRANSMITTALLib. _
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine & "Database preprocessing: " & pFile.sourcePath)
Return 1
End Function
End Class
C#: // Custom class used to monitor the processing of a drawing
internal class MyTransDbNotifier : TransmittalDatabaseNotificationHandler
public int preDatabaseProcessing(object pDatabase, TRANSMITTALLib.TransmittalFile pFile,
TRANSMITTALLib.TransmittalOperation pTransmit)
WriteMessage(Environment.NewLine + "Database preprocessing: " + pFile.sourcePath);
return 1;
相关参考 |
GMT+8, 2026-10-27 07:16
