PostSheetSetProcessing 事件 (ActiveX/ATO)
在处理图纸集后触发。 支持的平台:仅限 Windows 命名空间:传输塔利布 集会:AcETransmit19.tlb 签名VB.NET: Friend Class custom_class_name
Implements ITransmittalSheetSetNotification
Public Sub postSheetSetProcessing(pISheetSet As Object, _
pFile As TransmittalFile, _
pTransmit As TransmittalOperation) _
Implements ITransmittalSheetSetNotification.postSheetSetProcessing
End Class
C#: internal class custom_class_name : ITransmittalSheetSetNotification
public void postSheetSetProcessing(object pISheetSet,
TransmittalFile pFile,
TransmittalOperation pTransmit)
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本
例子VB.NET: ' Custom class used to monitor the processing of a sheet set
Friend Class MyTransSSMNotifier
pFile As TRANSMITTALLib.TransmittalFile, _
pTransmit As TRANSMITTALLib.TransmittalOperation) _
Implements TRANSMITTALLib.ITransmittalSheetSetNotification.postSheetSetProcessing
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine & "Sheet Set post processing: " & pFile.sourcePath)
End Class
C#: // Custom class used to monitor the processing of a sheet set
internal class MyTransSSMNotifier : ITransmittalSheetSetNotification
public void postSheetSetProcessing(object pISheetSet, TRANSMITTALLib.TransmittalFile pFile,
TRANSMITTALLib.TransmittalOperation pTransmit)
WriteMessage(Environment.NewLine + "Sheet Set post processing: " + pFile.sourcePath);
相关参考 |
GMT+8, 2026-11-3 20:56
