GetTransmittalReport 方法 (ActiveX/ATO)
2024-5-18 16:56| 发布者: admin| 查看: 910| 评论: 0|原作者: admin|来自: AutoCAD
返回包含将作为传递包的一部分包含的报表的文本字符串。
命名空间:传输塔利布
集会:AcETransmit19.tlb
VB.NET:
RetVal = object.getTransmittalReport()
C#:
RetVal = object.getTransmittalReport();
类型:TransmittalOperation 对象
此方法应用到的对象。
返回值 (RetVal)
类型:字符串
表示传递报告的文本内容的文本字符串。
发行信息
释放:AutoCAD 2005 及更高版本
  • AcETransmit19.tlb - AutoCAD 2015 及更高版本
  • AcETransmit18.tlb - AutoCAD 2010 到 AutoCAD 2014
    • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalOperation2ITransmittalOperation
  • AcETransmit16.tlb - AutoCAD 2005 到 AutoCAD 2009
    • 该方法是在 AutoCAD 2005 版本的库中引入的。getTransmittalReportITransmittalOperation2
VB.NET:
' Custom command that creates a transmittal package and adds a transmittal report
<CommandMethod("eTransmitCustomReport")> _
Public Shared Sub eTransmitCustomReport()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a file notification handler
    Dim fileHandler As New MyTransFileNotifier
    tro.subscribeToAddFileNotification(fileHandler)
    ' Setup the progress meter to monitor the files being added to the
    ' transmittal set from the sheet set
    Dim pmHandler As New MyProgressHandler
    tro.setProgressMeter(pmHandler, 1)
    ' Add a sheet set
    TransAddFile(tro, "C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", FileType.SheetSet)
    ' Append text to the transmittal report
    Dim nFirstSection As Integer = -1
    nFirstSection = tro.addToReport("Custom First Section:", nFirstSection)
    tro.addToReport(Environment.NewLine & "First line of first custom section.", nFirstSection)
    Dim nSecondSection As Integer = -1
    nSecondSection = tro.addToReport(Environment.NewLine & "Custom Second Section:", nSecondSection)
    tro.addToReport(Environment.NewLine & "First line of second custom section.", nSecondSection)
    ' Append text to the first section
    tro.addToReport(Environment.NewLine & "Second line of first custom section.", nFirstSection)
    ' Get the transmittal report
    Dim tr As String = tro.getTransmittalReport()
    ' Write the transmittal report to the file "transmittal report.txt" in the
    ' destination root of the transmittal package
    writeReport(Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + _
                "\transmittal report.txt", tro.getTransmittalReport())
    ' Add the report to the transmittal package
    Dim tf As TransmittalFile = TransAddFile(tro, _
                "\transmittal report.txt", FileType.Unknown, Nothing)
    ' Change the path of the transmittal report
    tf.targetSubPath = ""
    ' Remove the file notification handler
    tro.cancelSubscriptionToAddFileNotification(fileHandler)
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command that creates a transmittal package and adds a transmittal report
[CommandMethod("eTransmitCustomReport")]
public static void eTransmitCustomReport()
    TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(),
                                   "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a file notification handler
    MyTransFileNotifier fileHandler = new MyTransFileNotifier();
    tro.subscribeToAddFileNotification(fileHandler);
    // Setup the progress meter to monitor the files being added to the
    // transmittal set from the sheet set
    MyProgressHandler pmHandler = new MyProgressHandler();
    tro.setProgressMeter(pmHandler, 1);
    // Add a sheet set
    TransAddFile(tro, "C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst",
                 FileType.SheetSet);
    // Append text to the transmittal report
    int nFirstSection = -1;
    nFirstSection = tro.addToReport("Custom First Section:", nFirstSection);
    tro.addToReport(Environment.NewLine + "First line of first custom section.", nFirstSection);
    int nSecondSection = -1;
    nSecondSection = tro.addToReport(Environment.NewLine + "Custom Second Section:", nSecondSection);
    tro.addToReport(Environment.NewLine + "First line of second custom section.", nSecondSection);
    // Append text to the first section
    tro.addToReport(Environment.NewLine + "Second line of first custom section.", nFirstSection);
    // Get the transmittal report
    string tr = tro.getTransmittalReport();
    // Write the transmittal report to the file "transmittal report.txt" in the
    // destination root of the transmittal package
                "\\transmittal report.txt", tro.getTransmittalReport());
    // Add the report to the transmittal package
    TransmittalFile tf = TransAddFile(tro,
                "\\transmittal report.txt", FileType.Unknown, null);
    // Change the path of the transmittal report
    tf.targetSubPath = "";
    // Remove the file notification handler
    tro.cancelSubscriptionToAddFileNotification(fileHandler);
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-10-27 04:48
