GetTransmittalInfoInterface 方法 (ActiveX/ATO)
2024-5-18 16:56| 发布者: admin| 查看: 868| 评论: 0|原作者: admin|来自: AutoCAD
返回用于存储用于创建传递包的设置的信息对象。
命名空间:传输塔利布
集会:AcETransmit19.tlb
VB.NET:
RetVal = object.getTransmittalInfoInterface()
C#:
RetVal = object.getTransmittalInfoInterface();
类型:TransmittalOperation 对象
此方法应用到的对象。
返回值 (RetVal)
类型:TransmittalInfo 对象
传递集的信息对象。
发行信息
释放:AutoCAD 2005 及更高版本
  • AcETransmit19.tlb - AutoCAD 2015 及更高版本
  • AcETransmit18.tlb - AutoCAD 2010 到 AutoCAD 2014
    • 和 接口已与 AutoCAD 2010 版库中的接口合并。ITransmittalOperation2ITransmittalOperation3ITransmittalOperation
  • AcETransmit16.tlb - AutoCAD 2005 到 AutoCAD 2009
    • 该方法已使用 AutoCAD 2008 版库中的界面进行了修改。该方法返回了一个对象。getTransmittalInfoInterfaceITransmittalOperation3ITransmittalInfo2
    • 该方法是在 AutoCAD 2005 版本的库中引入的。getTransmittalInfoInterfaceITransmittalOperation2
VB.NET:
' Custom command to create a transmittal package with a drawing file
<CommandMethod("eTransmitDWGFile")> _
Public Shared Sub eTransmitDWGFile()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a DWG file
    Dim tf As TransmittalFile = Nothing
    tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", tf)
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command to create a transmittal package with a drawing file
[CommandMethod("eTransmitDWGFile")]
public static void eTransmitDWGFile()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a DWG file
    TransmittalFile tf = null;
    tro.addDrawingFile("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\A-02.dwg", out tf);
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-11-3 19:44
