ArchiveSheetSet 方法 (ActiveX/ATO)
2024-5-18 16:56| 发布者: admin| 查看: 814| 评论: 0|原作者: admin|来自: AutoCAD
将图纸集 (DST) 文件中的文件添加到传递集。
命名空间:传输塔利布
集会:AcETransmit19.tlb
VB.NET:
RetVal = object.archiveSheetSet(pISheetSet, includeSSFiles)
C#:
RetVal = object.archiveSheetSet(pISheetSet, includeSSFiles);
类型:TransmittalOperation 对象
此方法应用到的对象。
pISheetSet
访问:仅输入
类型: AcSmSheetSet
对象在库中定义。AcSmSheetSetAcSmComponents
includeSS软件
访问:仅输入
类型:长
  • 0 (): 不包括 DST 文件引用的工作表集 (DST) 和支持文件False
  • 1 ():包括 DST 文件引用的工作表集 (DST) 和支持文件True
返回值 (RetVal)
类型:未知/对象
发行信息
释放:AutoCAD 2005 及更高版本
  • AcETransmit19.tlb - AutoCAD 2015 及更高版本
  • AcETransmit18.tlb - AutoCAD 2010 到 AutoCAD 2014
  • AcETransmit16.tlb - AutoCAD 2005 到 AutoCAD 2009
VB.NET:
' Custom command to create a transmittal package from a sheet set
<CommandMethod("eTransmitDSTFile")> _
Public Shared Sub eTransmitDSTFile()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a file notification handler
    Dim fileHandler As New MyTransFileNotifier
    tro.subscribeToAddFileNotification(fileHandler)
    ' Setup the progress meter for use with sheet selection sets, _
    ' sheet sets, and the creation of a transmittal package
    Dim pmHandler As New MyProgressHandler
    tro.setProgressMeter(pmHandler, 1)
    ' Add a sheet set and the drawings referenced in it
    ' Get a reference to the Sheet Set Manager object
    Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr
    ' Open a sheet set (DST) file
    Dim sheetSetDatabase As AcSmDatabase = _
        sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False)
    ' Get the sheet set from the database and process it
    ' 0 - Do not include DST file or support files referenced
    '     by the DST file (templates, blocks, ...)
    ' 1 - Include DST file, all files referenced by the DST file,
    '     its(sheets And references)
    tro.archiveSheetSet(sheetSetDatabase.GetSheetSet(), vbTrue)
    ' Close the sheet set
    sheetSetManager.Close(sheetSetDatabase)
    ' Remove the file notification handler
    tro.cancelSubscriptionToAddFileNotification(fileHandler)
    ' Remove the progress meter handler
    pmHandler = Nothing
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command to create a transmittal package from a sheet set
[CommandMethod("eTransmitDSTFile")]
public static void eTransmitDSTFile()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a file notification handler
    MyTransFileNotifier fileHandler = new MyTransFileNotifier();
    tro.subscribeToAddFileNotification(fileHandler);
    // Setup the progress meter for use with sheet selection sets, _
    // sheet sets, and the creation of a transmittal package
    MyProgressHandler pmHandler = new MyProgressHandler();
    tro.setProgressMeter(pmHandler, 1);
    // Add a sheet set and the drawings referenced in it
    // Get a reference to the Sheet Set Manager object
    IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
    // Open a sheet set (DST) file
    AcSmDatabase sheetSetDatabase =
        sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false);
    // Get the sheet set from the database and process it
    // 0 - Do not include DST file or support files referenced
    //     by the DST file (templates, blocks, ...)
    // 1 - Include DST file, all files referenced by the DST file,
    //     its(sheets And references)
    tro.archiveSheetSet(sheetSetDatabase.GetSheetSet(), 1);
    // Close the sheet set
    sheetSetManager.Close(sheetSetDatabase);
    // Remove the file notification handler
    tro.cancelSubscriptionToAddFileNotification(fileHandler);
    // Remove the progress meter handler
    pmHandler = null;
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-10-28 04:51
