AddSheetSelset 方法 (ActiveX/ATO)
将图纸集选区中的图形文件添加到传递集。 支持的平台:仅限 Windows 命名空间:传输塔利布 集会:AcETransmit19.tlb 签名VB.NET: object.addSheetSelset pISheetSelset, includeSSFiles C#: object.addSheetSelset(pISheetSelset, includeSSFiles);
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本
例子VB.NET: ' Custom command to create a transmittal package from a sheet selection set in a sheet set
<CommandMethod("eTransmitDSTFile_SheetSelSet")> _
Public Shared Sub eTransmitDSTFile_SheetSelSet()
Dim ti As TransmittalInfo = _
TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
' Add a sheet selection set from a sheet set
' and the drawings contained in it
' Get a reference to the Sheet Set Manager object
Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr
' Open a Sheet Set file
Dim sheetSetDatabase As AcSmDatabase = _
sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False)
' Get all the SheetSelSets in the sheet set
Dim sheetSelSetEnum As IAcSmEnumSheetSelSet = _
sheetSetDatabase.GetSheetSet().GetSheetSelSets().GetEnumerator()
' Get the first SheetSelSet
Dim sheetSelSet As AcSmSheetSelSet = sheetSelSetEnum.Next()
Dim sheetSelSetFound As AcSmSheetSelSet = Nothing
' Check to the see if it is the requested SheetSelSet,
' if not get the next and check
While Not sheetSelSet Is Nothing
If UCase(sheetSelSet.GetName()). _
Equals("ELEVATIONS") = True Then
sheetSelSetFound = sheetSelSet
End If
sheetSelSet = sheetSelSetEnum.Next()
End While
' Get the sheet set from the database and process it
' 0 - Do not include DST file or support files referenced
' by the DST file (templates, blocks, ...)
' 1 - Include DST file, all files referenced by the
' DST file, its sheets and references
If Not sheetSelSetFound Is Nothing Then
tro.addSheetSelset(sheetSelSetFound, 0)
End If
' Close the sheet set
sheetSetManager.Close(sheetSetDatabase)
' Create the transmittal package
' Files are copied and resaved to the path specified by the destinationRoot property
' and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage()
C#: // Custom command to create a transmittal package from a sheet selection set in a sheet set
[CommandMethod("eTransmitDSTFile_SheetSelSet")]
public static void eTransmitDSTFile_SheetSelSet()
TransmittalInfo ti =
TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
// Add a sheet set and the drawings referenced in it
// Get a reference to the Sheet Set Manager object
IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
// Open a sheet set (DST) file
AcSmDatabase sheetSetDatabase =
sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false);
// Get all the SheetSelSets in the sheet set
IAcSmEnumSheetSelSet sheetSelSetEnum =
sheetSetDatabase.GetSheetSet().GetSheetSelSets().GetEnumerator();
// Get the first SheetSelSet
AcSmSheetSelSet sheetSelSet = sheetSelSetEnum.Next();
AcSmSheetSelSet sheetSelSetFound = null;
// Check to the see if it is the requested SheetSelSet,
// if not get the next and check
while (sheetSelSet != null)
if (sheetSelSet.GetName().ToUpper().Equals("ELEVATIONS") == true)
sheetSelSetFound = sheetSelSet;
// Get the sheet set from the database and process it
// 0 - Do not include DST file or support files referenced
// by the DST file (templates, blocks, ...)
// 1 - Include DST file, all files referenced by the
// DST file, its sheets and references
if (sheetSelSet != null)
tro.addSheetSelset(sheetSelSet, 1);
// Close the sheet set
sheetSetManager.Close(sheetSetDatabase);
// Create the transmittal package
// Files are copied and resaved to the path specified by the destinationRoot property
// and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage();
相关参考 |
GMT+8, 2026-10-28 01:27
