ObjectARX 开发指南
将 VBA 或 VB 中的错误处理程序与 VB.NET (.NET) 进行比较
2023-1-1 08:50| 发布者: admin| 查看: 1562| 评论: 0|来自: AutoCAD
VBA 或 VB 中的错误处理是使用语句完成的。虽然这些语句可以毫无问题地与 VB.NET 一起使用,但建议改用语句。 语句比 AND 语句更灵活。On ErrorOn ErrorTryTryOn Error Resume NextOn Error GoTo Label
可以使用语句重写 and 语句的用法。下面演示如何使用 重写语句。On Error Resume NextOn Error GoTo LabelTry-CatchOn Error GoTo LabelTry-Catch
出错时 - VBA
Sub ColorEntities()
    On Error GoTo MyErrorHandler
    Dim entry As Object
    For Each entry In ThisDrawing.ModelSpace
        entry.color = acRed
    Next entry
    ' Important! Exit the subroutine before the error handler
  Exit Sub
MyErrorHandler:
    MsgBox entry.EntityName + " is on a locked layer." + _
                              " The handle is: " + entry.Handle
  Resume Next
试捕 - VB.NET
<CommandMethod("ColorEntities")> _
Public Sub ColorEntities()
  '' Get the current document and database, and start a transaction
      '' Open the Block table record for read
      Dim acBlkTbl As BlockTable
                                   OpenMode.ForRead)
      '' Open the Block table record Model space for read
                                      OpenMode.ForRead)
      Dim acObjId As ObjectId
      '' Step through each object in Model space
      For Each acObjId In acBlkTblRec
          Try
              Dim acEnt As Entity
              acEnt = acTrans.GetObject(acObjId, _
                                        OpenMode.ForWrite)
              acEnt.ColorIndex = 1
          Catch
              Application.ShowAlertDialog(acObjId.ObjectClass.DxfName & _
                                          " is on a locked layer." & _
                                          " The handle is: " & acObjId.Handle.ToString())
          End Try
      Next
      acTrans.Commit()
  End Using
GMT+8, 2026-10-27 08:59
