布局或页面设置的打印设备名称存储在属性中。该名称应与系统上的某个设备匹配,否则将使用默认设备。PlotConfigurationName 您可以使用对象的方法获取 AutoCAD 有权访问的所有可用系统和非系统设备的列表。列出的设备与“打印”(Plot) 或“页面设置”(Page Setup) 对话框中显示的设备相同。GetPlotDeviceListPlotSettingsValidator 列出可用的输出设备此示例列出了可用的输出设备。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.PlottingServices
' Lists the available plotters (plot configuration [PC3] files)
<CommandMethod("PlotterList")> _
Public Shared Sub PlotterList()
' Get the current document and database, and start a transaction
acDoc.Editor.WriteMessage(vbLf & "Plot devices: ")
For Each plotDevice As String In PlotSettingsValidator.Current.GetPlotDeviceList()
' Output the names of the available plotter devices
acDoc.Editor.WriteMessage(vbLf & " " & plotDevice)
Next
using Autodesk.AutoCAD.PlottingServices;
// Lists the available plotters (plot configuration [PC3] files)
[CommandMethod("PlotterList")]
public static void PlotterList()
// Get the current document and database, and start a transaction
acDoc.Editor.WriteMessage("\nPlot devices: ");
foreach (string plotDevice in PlotSettingsValidator.Current.GetPlotDeviceList())
// Output the names of the available plotter devices
acDoc.Editor.WriteMessage("\n " + plotDevice);
相关概念父主题: |
GMT+8, 2026-10-27 05:25
