Plugin 属性 (ActiveX/CSP)
2024-5-18 16:55| 发布者: admin| 查看: 774| 评论: 0|原作者: admin|来自: AutoCAD
指定与错误关联的插件。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
VB.NET:
object.Plugin
C#:
object.Plugin;
类型:AcStError 对象
此属性应用于的对象。
只读:不
类型:IAcStPlugin2 接口
与错误关联的插件。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Sub PlugIn_Next() _
           Implements IAcStPlugin2.Next
    m_pError = Nothing
    If m_ContextList.Count > 0 Then
        ' Check to see if there are objects to check
        ' << Change based on standards implementation >>
        If m_LayerCacheArray.Length() > 0 Then
            Dim bFoundError As Boolean
            ' Check to see if this is the last object to be checked
            If m_curIndex < m_ContextList.Count - 1 Then
                m_curIndex = m_curIndex + 1
                bFoundError = False
                Dim layerObj As AcadLayer
                Dim iCache As Integer
                ' Iterate the objects to be checked
                While m_curIndex < m_ContextList.Count
                    ' Get the ObjectId of the object to be checked
                    layerObj = m_pCheckDatabase.ObjectIdToObject(m_ContextList.Item(m_curIndex))
                    ' Iterate through each of the standards objects and check for a match based on name
                    For iCache = LBound(m_LayerCacheArray) To UBound(m_LayerCacheArray)
                        ' Compare the names of the two layers
                        If (layerObj.Name.CompareTo(m_LayerCacheArray(iCache).Name) <> 0) Then
                            ' Check to see if the object is a macth,
                            ' if not flag as possible error
                            bFoundError = True
                        Else
                            bFoundError = False
                            ' Layer names matched, compare color and linetype values
                            If layerObj.color.ToString() <> m_LayerCacheArray(iCache).Color.ToString() Or _
                               layerObj.Lineweight.ToString() <> m_LayerCacheArray(iCache).Lineweight.ToString() Then
                                bFoundError = True
                            End If
                            ' Exit For loop since a match by name was found
                            Exit For
                        End If
                    Next
                    ' No match or a property difference was found
                    If bFoundError = True Then
                        Dim pError As New AcStError()
                        ' Assign a description to the error
                        pError.Description = "Layer is non-standard"
                        ' Assign an ObjectId to the error
                        pError.BadObjectId = layerObj.ObjectID
                        ' Assign the name of the object, plug-in, and error type
                        pError.BadObjectName = layerObj.Name
                        pError.Plugin = m_pPlugin
                        pError.ErrorTypeName = "Layer "
                        ' Assign a result status to the error
                        pError.ResultStatus = AcStResultStatus.acStResFlagsNone
                        ' Assign the object's property values to the error for checking
                        If pError.PropertyCount = 0 Then
                            pError.PropertyValuePut("Color", layerObj.color)
                            pError.PropertyValuePut("Lineweight", layerObj.Lineweight)
                        End If
                        m_pError = pError
                        bFoundError = False
                        Exit While
                    End If
                    ' Increment the counter
                End While
            End If
        End If
    End If
C#:
public void PlugIn_Next()
    m_pError = null;
    if (m_ContextList.Count > 0)
        AcadLayer layerObj = default(AcadLayer);
        int iCache = 0;
        bool bFoundError = false;
        // Check to see if there are objects to check
        // << Change based on standards implementation >>
        if (m_LayerCacheArray.Length > 0)
            // Check to see if this is the last object to be checked
            if (m_curIndex < m_ContextList.Count - 1)
                m_curIndex = m_curIndex + 1;
                // Iterate the objects to be checked
                while (m_curIndex < m_ContextList.Count)
                    // Get the ObjectId of the object to be checked
                    layerObj = (AXDBLib.AcadLayer)m_pCheckDatabase.ObjectIdToObject((long)m_ContextList.GetItem(m_curIndex));
                    int nLBound = m_LayerCacheArray.GetLowerBound(0);
                    int nUBound = m_LayerCacheArray.GetUpperBound(0);
                    // Iterate through each of the standards objects and check for a match based on name
                    for (iCache = nLBound; iCache <= nUBound; iCache++)
                        // Compare the names of the two layers
                        if ((layerObj.Name.CompareTo(m_LayerCacheArray[iCache].Name) != 0))
                            // Check to see if the object is a macth,
                            // if not flag as possible error
                            bFoundError = true;
                        else
                            // Layer names matched, compare color and linetype values
                            if (layerObj.color.ToString() != m_LayerCacheArray[iCache].Color.ToString() |
                                layerObj.Lineweight.ToString() != m_LayerCacheArray[iCache].Lineweight.ToString())
                                bFoundError = true;
                            // Exit For loop since a match by name was found
                            break;
                    // No match or a property difference was found
                    if (bFoundError == true)
                        AcStError pError = new AcStError();
                        // Assign a description to the error
                        pError.Description = "Layer is non-standard";
                        // Assign an ObjectId to the error
                        pError.BadObjectId = layerObj.ObjectID;
                        // Assign the name of the object, plug-in, and error type
                        pError.BadObjectName = layerObj.Name;
                        pError.Plugin = m_pPlugin;
                        pError.ErrorTypeName = "Layer ";
                        // Assign a result status to the error
                        pError.ResultStatus = AcStResultStatus.acStResFlagsNone;
                        // Assign the object's property values to the error for checking
                        if (pError.PropertyCount == 0)
                            pError.PropertyValuePut("Color", (ACAD_COLOR)layerObj.color);
                            pError.PropertyValuePut("Lineweight", (ACAD_LWEIGHT)layerObj.Lineweight);
                        m_pError = pError;
                        break;
                    // Increment the counter
GMT+8, 2026-10-27 21:29
