BadObjectId 属性 (ActiveX/CSP)
2024-5-18 16:55| 发布者: admin| 查看: 818| 评论: 0|原作者: admin|来自: AutoCAD
指定其属性与要比较的图形标准文件中定义的对象不匹配的对象的对象 ID。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
VB.NET:
object.BadObjectId
C#:
object.BadObjectId;
类型:AcStError 对象
此属性应用于的对象。
只读:不
类型:LongPtr (长)
与错误关联的对象的对象 ID。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Sub PlugIn_Start(ByVal pStartError As AcStError) _
                        Implements IAcStPlugin2.Start
    ' If pStartError is an object, checking should start
    ' from that error, not the beginning of the current context.
    If IsNothing(pStartError) = False Then
        ' Get the ObjectId of the first object to check
        Dim badId As Long = pStartError.BadObjectId
        ' Find the index for ObjectId in the context list stored in m_objIDArray
        For m_curIndex = 0 To m_ContextList.Count - 1
            If m_ContextList.Item(m_curIndex) = badId Then
                m_curIndex = m_curIndex - 1
                PlugIn_Next()
            End If
        Next
    Else
        ' A valid AcStError object was not passed to the method.
        ' Checking should start at the beginning of the context list.
        m_curIndex = -1
        PlugIn_Next()
    End If
C#:
public void PlugIn_Start(AcStError pStartError)
    // If pStartError is an object, checking should start
    // from that error, not the beginning of the current context.
    if ((pStartError == null) == false)
        // Get the ObjectId of the first object to check
        long badId = pStartError.BadObjectId;
        // Find the index for ObjectId in the context list stored in m_objIDArray
        for (m_curIndex = 0; m_curIndex <= m_ContextList.Count - 1; m_curIndex++)
            if (Convert.ToInt64(m_ContextList.GetItem(m_curIndex)) == badId)
                m_curIndex = m_curIndex - 1;
                PlugIn_Next();
    else
        // A valid AcStError object was not passed to the method.
        // Checking should start at the beginning of the context list.
        m_curIndex = -1;
        PlugIn_Next();
GMT+8, 2026-10-28 03:07
