SetupForAudit 方法 (ActiveX/CSP)
定义插件将在其中运行的上下文,特别是要检查的数据库和将用于检查的图形标准 (DWS) 文件。 支持的平台:仅限 Windows 命名空间:AcStMgr (英语) 集会:AcStMgr.tlb 签名VB.NET: Public Sub SetupForAudit(pDb, szPathName, stdNameArray, stdPathArray, stdDbArray) _
Implements IAcStPlugin2.SetupForAudit
C#: public void SetupForAudit(pDb, szPathName, stdNameArray, stdPathArray, stdDbArray)
返回值 (RetVal)无返回值。 言论要检查的对象由接口的方法指定。在编辑会话期间,它可能会不时变化。SetContextIAcStPlugin2 传递给此方法的对象保证在插件的生存期内有效。插件应将此对象缓存在插件的成员变量中,以允许从其他插件方法访问对象。AcadDatabase 插件不应缓存传递给 stdDbArray 参数的对象。标准主机应用程序在获取迭代器后可以自由关闭DWS文件,从而使数据库对象失效。需要DWS文件中信息的插件应使用此方法缓存来自DWS文件的信息,例如将必要的数据复制到内存中缓存。AcadDatabase 发行信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub SetupForAudit(ByVal pDb As AcadDatabase, _
ByVal szPathName As String, _
ByVal stdNameArray As Object, _
ByVal stdPathArray As Object, _
ByVal stdDbArray As Object) _
' Used to define the context which the plug-in will operate.
' The drawing to be checked and the DWS files being used are passed
' to the plug-in at this point. Store the DWS standards definitions
' and the objects to be checked. The GetObjectFilter() method is used
' to specify the object type that the plug-in should check for errors.
' WARNING!: Do not save a reference to the database object,
' as it may not be valid going forward.
If Not IsNothing(pDb) Then
' Store a reference to the DWG to be checked
m_pCheckDatabase = pDb
' Verify the reference to the DWG is valid object
If Not IsNothing(m_pCheckDatabase) Then
' << Change based on standards implementation >>
For Each acObj As AcadObject In m_pCheckDatabase.Layers
If acObj.ObjectName = "AcDbLayerTableRecord" Then
m_ContextList.Add(acObj.ObjectID, True)
End If
Next
End If
Dim iDWS As Integer
' Iterate each of the DWS files and cache the objects to use to fix errors
For iDWS = 0 To UBound(stdDbArray)
' Get the DWS database
m_pDWSDatabase = stdDbArray(iDWS)
Dim pStdLayer As AcadLayer
' Iterate the layers in the database
Dim i As Integer = 0
For Each pStdLayer In m_pDWSDatabase.Layers
Dim layerCache As New LayerCache()
' Cache the properties of the layers in the DWS database
layerCache.Name = pStdLayer.Name
layerCache.Color = pStdLayer.color
layerCache.Lineweight = pStdLayer.Lineweight
layerCache.StandardFileName = stdNameArray(iDWS)
' Create a fix object to be used later to correct a standards violation
Dim pFix As New AcStFix()
pFix.Description = "Layer fix"
pFix.StandardFileName = layerCache.StandardFileName
pFix.FixObjectName = pStdLayer.Name
If pFix.PropertyCount = 0 Then
pFix.PropertyValuePut("Color", pStdLayer.color)
pFix.PropertyValuePut("Lineweight", pStdLayer.Lineweight)
End If
layerCache.StandardsFix = pFix
ReDim Preserve m_LayerCacheArray(i)
m_LayerCacheArray(i) = layerCache
layerCache = Nothing
pFix = Nothing
i = i + 1
Next
m_pDWSDatabase = Nothing
Next
End If
C#: public void SetupForAudit(AcadDatabase pDb, string szPathName, object stdNameArray,
object stdPathArray, object stdDbArray)
// Used to define the context which the plug-in will operate.
// The drawing to be checked and the DWS files being used are passed
// to the plug-in at this point. Store the DWS standards definitions
// and the objects to be checked. The GetObjectFilter() method is used
// to specify the object type that the plug-in should check for errors.
// WARNING!: Do not save a reference to the database object,
// as it may not be valid going forward.
if (pDb != null)
// Store a reference to the DWG to be checked
m_pCheckDatabase = pDb;
// Verify the reference to the DWG is valid object
if ((m_pCheckDatabase != null))
// << Change based on standards implementation >>
foreach (AcadObject acObj in m_pCheckDatabase.Layers)
if (acObj.ObjectName == "AcDbLayerTableRecord")
m_ContextList.Add(acObj.ObjectID, true);
int i = 0;
int iDWS = 0;
int nLBound = ((Array)stdDbArray).GetLowerBound(0);
int nUBound = ((Array)stdDbArray).GetUpperBound(0);
// Iterate each of the DWS files and cache the objects to use to fix errors
for (iDWS = 0; iDWS <= nUBound; iDWS++)
// Get the DWS database
m_pDWSDatabase = (AcadDatabase)((Array)stdDbArray).GetValue(iDWS);
// Iterate the layers in the database
foreach (AcadLayer pStdLayer in m_pDWSDatabase.Layers)
AdskLayersPlugin.StandardsHelpers.LayerCache oLayerCache = new AdskLayersPlugin.StandardsHelpers.LayerCache();
// Cache the properties of the layers in the DWS database
oLayerCache.Name = pStdLayer.Name;
oLayerCache.Color = (ACAD_COLOR)pStdLayer.color;
oLayerCache.Lineweight = (ACAD_LWEIGHT)pStdLayer.Lineweight;
oLayerCache.StandardFileName = (String)((Array)stdNameArray).GetValue(iDWS);
oLayerCache.ObjectId = pStdLayer.ObjectID;
// Create a fix object to be used later to correct a standards violation
AcStFix pFix = new AcStFix();
pFix.Description = "Layer fix";
pFix.StandardFileName = oLayerCache.StandardFileName;
pFix.FixObjectName = pStdLayer.Name;
pFix.FixObjectId = oLayerCache.ObjectId;
if (pFix.PropertyCount == 0)
pFix.PropertyValuePut("Color", (ACAD_COLOR)pStdLayer.color);
pFix.PropertyValuePut("Lineweight", (ACAD_LWEIGHT)pStdLayer.Lineweight);
oLayerCache.StandardsFix = pFix;
Array.Resize(ref m_LayerCacheArray, i + 1);
m_LayerCacheArray[i] = oLayerCache;
oLayerCache = null;
pFix = null;
i = i + 1;
m_pDWSDatabase = null;
GMT+8, 2026-10-28 06:09
