ObjectARX 开发指南
相关分类
纸张大小和单位 (.NET)
2023-1-1 09:53| 发布者: admin| 查看: 2190| 评论: 0|来自: AutoCAD
布局的纸张尺寸选择取决于为输出配置的绘图仪或设备。每个绘图仪或设备都有一个可用输出尺寸的标准列表,可以使用对象的方法获得这些输出尺寸。对象的方法可用于返回“打印”(Plot) 或“页面设置”(Page Setup) 对话框中显示的输出大小。可以使用该属性查询分配给布局的纸张大小。GetCanonicalMediaNameListPlotSettingsValidatorGetLocaleMediaNamePlotSettingsValidatorCanonicalMediaName
还可以使用该属性查询布局的单位。此属性返回枚举定义的三个值之一:、 或 。如果绘图仪配置为栅格输出,则输出大小以像素为单位返回。PlotPaperUnitsPlotPaperUnitInchesMillimetersPixels
列出输出设备的可用纸张尺寸
本示例列出了 DWF6 ePlot.pc3 输出设备的纸张尺寸。
VB.NET
Imports Autodesk.AutoCAD.PlottingServices
' Lists the available local media names for a specified plot configuration (PC3) file
<CommandMethod("PlotterLocalMediaNameList")> _
Public Shared Sub PlotterLocalMediaNameList()
    ' Get the current document and database, and start a transaction
    Using plSet As PlotSettings = New PlotSettings(True)
        Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
        ' Set the Plotter and page size
        acPlSetVdr.SetPlotConfigurationName(plSet, "DWF6 ePlot.pc3", _
                                            "ANSI_A_(8.50_x_11.00_Inches)")
        acDoc.Editor.WriteMessage(vbLf & "Canonical and Local media names: ")
        Dim cnt As Integer = 0
        For Each mediaName As String In acPlSetVdr.GetCanonicalMediaNameList(plSet)
            ' Output the names of the available media for the specified device
            acDoc.Editor.WriteMessage(vbLf & "  " & mediaName & " | " & _
                                      acPlSetVdr.GetLocaleMediaName(plSet, cnt))
            cnt = cnt + 1
        Next
    End Using
C#
using Autodesk.AutoCAD.PlottingServices;
// Lists the available local media names for a specified plot configuration (PC3) file
[CommandMethod("PlotterLocalMediaNameList")]
public static void PlotterLocalMediaNameList()
    // Get the current document and database, and start a transaction
    using(PlotSettings plSet = new PlotSettings(true))
        PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
        // Set the Plotter and page size
                                            "ANSI_A_(8.50_x_11.00_Inches)");
        acDoc.Editor.WriteMessage("\nCanonical and Local media names: ");
        int cnt = 0;
        foreach (string mediaName in acPlSetVdr.GetCanonicalMediaNameList(plSet))
            // Output the names of the available media for the specified device
            acDoc.Editor.WriteMessage("\n  " + mediaName + " | " +
                                      acPlSetVdr.GetLocaleMediaName(plSet, cnt));
            cnt = cnt + 1;
GMT+8, 2026-10-31 02:58
