ShadowDisplay 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 965| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的阴影显示属性。(已过时)
object.ShadowDisplay
类型:ShadowDisplay
应用此属性的对象。
只读:不
类型:枚举AcShadowDisplayType
  • acCastsAndReceivesShadows
  • acCastsShadows
  • acReceivesShadows
  • acIgnoreShadows
Sub Example_ShadowDisplay()
    ' This example creates a cone in model space and changes its shadow display setting.
    Dim coneObj As Acad3DSolid
    Set coneObj = ThisDrawing.ModelSpace.AddCone(centerPoint, 5, 20)
    Dim shadowObj As IAcadShadowDisplay
    Dim EnableShadowDisplayStatus As Long
    Dim ShadowDisplay As AcShadowDisplayType
    Dim displaySettingDesc As String
    Set shadowObj = coneObj
    EnableShadowDisplayStatus = shadowObj.EnableShadowDisplay
    ShadowDisplay = shadowObj.ShadowDisplay
    displaySettingDesc = DescribeShadowDisplay(ShadowDisplay)
    If EnableShadowDisplayStatus = 1 Then
        MsgBox "Shadow display is currently enabled for this object." & vbCr & _
            "Current shadow display setting is: " & displaySettingDesc
    Else
        MsgBox "Shadow display is disabled for this object."
    End If
    shadowObj.ShadowDisplay = acCastsShadows
    displaySettingDesc = DescribeShadowDisplay(shadowObj.ShadowDisplay)
    MsgBox "New shadow display setting is: " & displaySettingDesc
Private Function DescribeShadowDisplay(acShadow As AcShadowDisplayType) As String
    Select Case acShadow
        Case acCastsAndReceivesShadows:
            DescribeShadowDisplay = "cast and receive shadows."
        Case acCastsShadows:
            DescribeShadowDisplay = "cast shadows only."
        Case acReceivesShadows:
            DescribeShadowDisplay = "receive shadows only."
        Case acIgnoreShadows:
            DescribeShadowDisplay = "ignore shadows."
    End Select
End Function
(defun c:Example_ShadowDisplay()
    ;; This example creates a cone in model space and changes its shadow display setting.
    ;; AutoLISP cannot cast COM objects to different types, so you must change the Shadow Display
    ;; property via DXF code values.
    (setq centerPoint (vlax-3d-point 0 0 0))
    (setq coneObj (vla-AddCone modelSpace centerPoint 5 20))
    (setq ed (entget (vlax-vla-object->ename coneObj)))
    (setq shadowDisplay (assoc 284 ed))
    (if (= shadowDisplay nil)
        (setq shadowDisplay 0)
        (setq shadowDisplay (cdr shadowDisplay))
    (setq displaySettingDesc (DescribeShadowDisplay ShadowDisplay))
    (alert (strcat "Shadow display is currently enabled for this object."
                   "\nCurrent shadow display setting is: " displaySettingDesc))
    ;; Before changing the value, you should validate the object is not a Line or some other
    ;; 2D object that does not support shadows.
    (setq newShadowDisplay acCastsShadows)
    (if (/= (assoc 284 ed) nil)
        (setq ed (subst (cons 284 acCastsShadows) (assoc 284 ed) ed))
        (setq ed (append ed (list (cons 284 acCastsShadows))))
    (entmod ed)
    (entupd (vlax-vla-object->ename coneObj))
    (setq displaySettingDesc (DescribeShadowDisplay newShadowDisplay))
    (alert (strcat "New shadow display setting is: " displaySettingDesc))
(defun DescribeShadowDisplay (acShadow / )
    (cond
        ((= acShadow acCastsAndReceivesShadows) "cast and receive shadows.")
        ((= acShadow acCastsShadows) "cast shadows only.")
        ((= acShadow acReceivesShadows) "receive shadows only.")
        ((= acShadow acIgnoreShadows) "ignore shadows.")
GMT+8, 2026-10-27 00:38
