OwnerID32 属性 (ActiveX)
获取 64 位系统的所有者(父)对象的对象 ID。(已过时) 支持的平台:仅限 Windows 签名VBA: object.OwnerID32
属性值只读:是的 类型:长 对象所有者的对象 ID。 言论没有其他评论。 例子VBA: Sub Example_OwnerID32()
' This example creates an MText object in model space
' and then finds the OwnerID for the object.
Dim MTextObj As AcadMText
Dim corner(0 To 2) As Double
Dim width As Double
Dim text As String
corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
width = 10
text = "This is the text string for the MText object"
' Creates the MText object
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
ZoomAll
MsgBox "The OwnerID for the MText object is: " & MTextObj.OwnerID32
可视化 LISP: (vl-load-com)
(defun c:Example_OwnerID32()
;; This example creates an MText object in model space
;; and then finds the OwnerID for the object.
(setq corner (vlax-3d-point 0 10 0)
width 10
text "This is the text string for the MText object")
;; Creates the MText object
(setq MTextObj (vla-AddMText modelSpace corner width text))
(vla-ZoomAll acadObj)
(alert (strcat "The OwnerID for the MText object is: " (itoa (vla-get-OwnerID32 MTextObj))))
GMT+8, 2026-10-27 04:59
