IndexOf 方法 (ActiveX)
提供“文件依赖项列表”中条目的索引。(已过时) 支持的平台:仅限 Windows 签名VBA: RetVal = object.IndexOf(Feature, FullFileName)
返回值 (RetVal)类型:长 条目的索引。 言论没有其他评论。 例子VBA: Sub Example_IndexOf()
'This example adds an entry to the File Dependency List, returns its Index, updates
'the entry, and then removes the entry.
ThisDrawing.Application.Documents.Open ("c:\program files\autocad\sample\city map.dwg")
Dim objFDLCol As AutoCAD.AcadFileDependencies
Dim objFDL As AutoCAD.AcadFileDependency
Set objFDLCol = ThisDrawing.FileDependencies
MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.Count & ".")
Dim FDLIndex As Long
FDLIndex = objFDLCol.CreateEntry("acad:xref", "c:\referenced.dwg", True, True)
Dim IndexNumber As Long
IndexNumber = objFDLCol.IndexOf("acad:xref", "c:\referenced.dwg")
Dim IndexString As String
IndexString = CStr(IndexNumber)
MsgBox ("The index of the new entry is " & IndexString & ".")
objFDLCol.UpdateEntry (FDLIndex)
objFDLCol.RemoveEntry FDLIndex, True
可视化 LISP: (vl-load-com)
(defun c:Example_IndexOf()
;; This example adds an entry to the File Dependency List, returns its Index, updates
;; the entry, and then removes the entry.
(setq objFDLCol (vla-get-FileDependencies doc))
(alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) "."))
(setq FDLIndex (vla-CreateEntry objFDLCol "acad:xref"
(findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg") :vlax-true :vlax-true))
(setq IndexNumber (vla-IndexOf objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg")))
(alert (strcat "The index of the new entry is " (itoa IndexNumber) "."))
(vla-UpdateEntry objFDLCol FDLIndex)
(vla-RemoveEntry objFDLCol FDLIndex :vlax-true)
GMT+8, 2026-11-15 14:45
