GetBlockAttributeValue32 方法 (ActiveX)
对于 64 位系统,获取具有属性定义 ID 的块内容中的属性值。 (已过时) 支持的平台:仅限 Windows 签名 - MLeaderVBA: RetVal = object.GetBlockAttributeValue32(attdefId)
签名 - 表格VBA: RetVal = object.GetBlockAttributeValue32(row, col, attdefId)
返回值 (RetVal)类型:字符串 属性值。 言论没有其他评论。 例子VBA: Sub Example_Blockttribute()
' This example creates an MLeader object and gets and sets values for
' the block attribute type.
Dim points(0 To 5) As Double
points(0) = 0: points(1) = 4: points(2) = 0
points(3) = 1.5: points(4) = 5: points(5) = 0
Dim i As Long
Dim oML As AcadMLeader
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
oML.ContentType = acBlockContent
oML.ContentBlockType = acBlockBox
Dim sBlock As String
sBlock = oML.ContentBlockName
Dim o As AcadEntity
For Each o In ThisDrawing.Blocks(sBlock)
If o.ObjectName = "AcDbAttributeDefinition" Then
oML.SetBlockAttributeValue o.ObjectID, "123"
MsgBox oML.GetBlockAttributeValue(o.ObjectID)
End If
Next o
Update
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_BlockAttribute()
;; This example creates an MLeader object and gets and sets values for
;; the block attribute type.
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
(vlax-safearray-fill points '(0 4 0
1.5 5 0
(setq i 0)
(setq oML (vla-AddMLeader modelSpace points i))
(vla-put-ContentType oML acBlockContent)
(vla-put-ContentBlockType oML acBlockBox)
(setq sBlock (vla-get-ContentBlockName oML))
(vlax-for o (vla-Item (vla-get-Blocks doc) sBlock)
(if (= (vla-get-ObjectName o) "AcDbAttributeDefinition")
(progn
(vla-SetBlockAttributeValue oML (vla-get-ObjectID o) "123")
(alert (vla-GetBlockAttributeValue oML (vla-get-ObjectID o)))
(vla-Update acadObj)
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-27 04:52
