SysVarChanged 事件 (ActiveX)
在系统变量的值发生更改时触发。 支持的平台:仅限 Windows 签名VBA: object.SysVarChanged(SysVarName, NewVal)
言论此事件表示尝试更改系统变量。它不表示实际值已更改。在某些情况下,可以设置系统变量而不导致其值更改。例如,如果 FILLMODE 为 0,并且有人尝试将其设置为 0,则即使调用对 FILLMODE 的值没有实际影响,您也会得到该系统变量的事件。 显示模式对话框时不会触发任何事件。 例子VBA: Public WithEvents ACADApp As AcadApplication ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp) which will be used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.22")
Private Sub ACADApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Variant)
' This example intercepts an Application SysVarChanged event.
' This event is triggered when the value of a system variable is changed.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Change the value of a system variable in AutoCAD.
' For example: Type GRIDMODE on the command line and toggle the grid display on/off
' Use the "SysvarName" and "newVal" variables to determine which
' system variable has changed and its new value.
MsgBox "The system variable " & SysvarName & " was just changed to: " & newVal
可视化 LISP: Not available |
GMT+8, 2026-11-4 23:22
