SelectionChanged 事件 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 591| 评论: 0|原作者: admin|来自: AutoCAD
在当前 pickfirst 选择集更改时触发。
object.SelectionChanged()
类别: 文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是文档。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_SelectionChanged()
    ' This example intercepts a drawing SelectionChanged event.
    ' This event is triggered when the current selection set in a drawing is modified.
    ' To trigger this example event: Select or deselect objects in any open drawing
    MsgBox "The selection set in a drawing was just changed!"
Not available
GMT+8, 2026-10-28 04:51
