EndSave 事件 (ActiveX)
在AutoCAD完成图形保存时触发。 支持的平台:仅限 Windows 签名VBA: object.EndSave(Filename)
例子VBA: Private Sub AcadDocument_EndSave(ByVal FileName As String)
' This example intercepts a drawing EndSave event.
' This event is triggered when a drawing finishes a save request.
' To trigger this example event: Save an open drawing and wait for the save to complete
' Use the "FileName" variable to determine where the drawing file was saved
MsgBox "A drawing has just been saved to: " & FileName
可视化 LISP: Not available |
GMT+8, 2026-10-27 08:59
