BeginQuit 事件 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 691| 评论: 0|原作者: admin|来自: AutoCAD
在AutoCAD任务结束或文档关闭之前触发。
object.BeginQuit(Cancel)
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
取消
类型:布尔;处理程序的输出
  • True:中止AutoCAD的关闭。
  • False:允许继续关闭AutoCAD。
该事件标志着 AutoCAD 任务的结束。BeginQuit
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.22")
Private Sub ACADApp_BeginQuit(Cancel As Boolean)
    ' This example intercepts an Application BeginQuit event.
    ' This event is triggered when AutoCAD receives a request to shut down.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Close the AutoCAD application
    ' Use the "Cancel" variable to stop the shut down of the application
    If MsgBox("AutoCAD is about to shut down.  Do you want to continue with the shutdown?", _
              vbYesNoCancel + vbQuestion) <> vbYes Then
        Cancel = True
    End If
Not available
GMT+8, 2026-9-16 20:27
