BeginDoubleClick 事件 (ActiveX)
在用户双击图形中的对象后触发。 支持的平台:仅限 Windows 签名VBA: object.BeginDoubleClick(PickPoint)
言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant)
' This example intercepts a drawing BeginDoubleClick event.
' This event is triggered when a drawing receives
' a double mouse click in its working area.
' To trigger this example event: Position the mouse over the working area of
' a drawing window and double-click the left mouse button
' Use the "PickPoint" variable to determine where on the drawing the user clicked
MsgBox "A drawing has just been double-clicked at:" & vbCrLf & _
PickPoint(0) & vbCrLf & _
PickPoint(1) & vbCrLf & _
PickPoint(2)
可视化 LISP: Not available |
GMT+8, 2026-10-27 04:32
