激活事件 (ActiveX)
在激活文档窗口时触发。 支持的平台:仅限 Windows 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_Activate()
' This example intercepts a drawing Activate event.
' This event is triggered when a drawing window becomes active.
' To trigger this example event: Either open a new drawing or switch from
' one drawing window to another
MsgBox "You have just activated a drawing!"
可视化 LISP: Not available |
GMT+8, 2026-10-27 05:13
