XRefLayerVisibility 属性 (ActiveX)
确定与外部参照相关的图层的可见性,并指定是否保存嵌套的外部参照路径更改。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 当此属性设置为 时,图层设置将与当前图形的图层表一起保存,并在会话之间持续存在。嵌套的外部参照路径更改将与当前图形一起保存,并在会话之间持续存在。True 当此属性设置为 时,对当前图形中与外部参照相关的图层所做的更改仅在当前进程中有效,但不会与图形一起保存。当重新打开当前图形时,将从参考图形重新加载图层表,并且当前图形将反映这些设置。受影响的图层设置包括:开/关、冻结/解冻、颜色和线型。此设置还指定对嵌套外部参照路径所做的更改仅适用于当前进程,而不与图形一起保存。False 注意:此属性的值存储在 VISRETAIN 系统变量中。
例子VBA: Sub Example_XRefLayerVisibility()
' This example reads and modifies the preference value that controls
' the visibility of xref-dependent layers and specifies if nested xref
' path changes are saved.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.XRefLayerVisibility
MsgBox "The XRefLayerVisibility preference is set to: " & originalValue
' Modify the XRefLayerVisibility preference by toggling the value
ACADPref.XRefLayerVisibility = Not (ACADPref.XRefLayerVisibility)
newValue = ACADPref.XRefLayerVisibility
MsgBox "The XRefLayerVisibility preference has been set to: " & newValue
' this preference in effect
ACADPref.XRefLayerVisibility = originalValue
MsgBox "The XRefLayerVisibility preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_XRefLayerVisibility()
;; This example reads and modifies the preference value that controls
;; the visibility of xref-dependent layers and specifies if nested xref
;; path changes are saved.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-XRefLayerVisibility preferences))
(alert (strcat "The XRefLayerVisibility preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the XRefLayerVisibility preference by toggling the value
(vla-put-XRefLayerVisibility preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The XRefLayerVisibility preference has been set to: " (if (= (vla-get-XRefLayerVisibility preferences) :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-XRefLayerVisibility preferences originalValue)
(alert (strcat "The XRefLayerVisibility preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 05:42
