XRefEdit 属性 (ActiveX)
确定当前图形在被其他用户引用时是否可以就地编辑。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值存储在 XEDIT 系统变量中。
例子VBA: Sub Example_XRefEdit()
' This example reads and modifies the preference value that controls
' whether the current drawing can be edited in place when being
' referenced by another user.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.XRefEdit
MsgBox "The XRefEdit preference is set to: " & originalValue
' Modify the XRefEdit preference by toggling the value
ACADPref.XRefEdit = Not (ACADPref.XRefEdit)
newValue = ACADPref.XRefEdit
MsgBox "The XRefEdit preference has been set to: " & newValue
' this preference in effect
ACADPref.XRefEdit = originalValue
MsgBox "The XRefEdit preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_XRefEdit()
;; This example reads and modifies the preference value that controls
;; whether the current drawing can be edited in place when being
;; referenced by another user.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-XRefEdit preferences))
(alert (strcat "The XRefEdit preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the XRefEdit preference by toggling the value
(vla-put-XRefEdit preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The XRefEdit preference has been set to: " (if (= (vla-get-XRefEdit preferences) :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-XRefEdit preferences originalValue)
(alert (strcat "The XRefEdit preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 00:37
