XRefDatabase 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 866| 评论: 0|原作者: admin|来自: AutoCAD
获取定义块内容的 Database 对象。
object.XRefDatabase
类型:块
此属性应用于的对象。
只读:是的
类型: 数据库
定义块内容的对象。Database
仅当块的属性等于 时,此属性才可用。IsXRefTrue
Sub Example_XRefDatabase()
    ' This example adds an external reference to the current drawing.
    ' It then cycles through each Block object in the drawing
    ' and determines the style of each Block by accessing the
    ' IsLayout and IsXRef properties of the Block. If the Block is an
    ' XRef Block, you obtain a reference to the external Database object
    ' for that Block and display the number of Blocks the Database contains.
    Dim InsertPoint(0 To 2) As Double
    Dim insertedBlock As AcadExternalReference
    Dim tempBlock As AcadBlock
    Dim msg As String, PathName As String
    ' Define external reference to be inserted
    InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
    PathName = "c:\program files\autocad\sample\city map.dwg"
    ' Add the external block to model space
    Set insertedBlock = ThisDrawing.ModelSpace.AttachExternalReference(PathName, "XREF_IMAGE", InsertPoint, 1, 1, 1, 0, False)
    msg = vbCrLf & vbCrLf
    For Each tempBlock In ThisDrawing.Blocks
        If tempBlock.IsXRef Then
            ' Block is an external reference, so add it to list
            msg = msg & tempBlock.name & " contains " & _
            tempBlock.XRefDatabase.Blocks.count & " blocks"
            msg = msg & vbCrLf      ' Insert line
        End If
    Next
    ' Display Block information for the XRefDatabase
    MsgBox "Externally referenced blocks attached to this drawing have the following block counts: " & msg
(defun c:Example_XRefDatabase()
    ;; This example adds an external reference to the current drawing.
    ;; It then cycles through each Block object in the drawing
    ;; and determines the style of each Block by accessing the
    ;; IsLayout and IsXRef properties of the Block. If the Block is an
    ;; XRef Block, you obtain a reference to the external Database object
    ;; for that Block and display the number of Blocks the Database contains.
    ;; Define external reference to be inserted
    (setq InsertPoint (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external block to model space
    (setq insertedBlock (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" InsertPoint 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (setq msg "")
    (vlax-for tempBlock (vla-get-Blocks doc)
        (if (= (vla-get-IsXRef tempBlock) :vlax-true)
            (progn
                ;; Block is an external reference, so add it to list
                (setq msg (strcat msg (vla-get-Name tempBlock) " contains "
                                  (itoa (vla-get-Count (vla-get-Blocks (vla-get-XRefDatabase tempBlock)))) " blocks\n"))
    ;; Display Block information for the XRefDatabase
    (alert (strcat "Externally referenced blocks attached to this drawing have the following block counts: " msg))
GMT+8, 2026-10-27 03:27
