WorkspacePath 属性 (ActiveX)
指定数据库工作区文件的路径。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 数据库工作区文件的驱动器、路径和文件名。 言论没有其他评论。 例子VBA: Sub Example_WorkspacePath()
' This example reads and modifies the preference value that controls
' the path for the database workspace file.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesFiles
' Get the files preferences object
Set ACADPref = ThisDrawing.Application.preferences.Files
originalValue = ACADPref.WorkspacePath
MsgBox "The WorkspacePath preference is set to: " & originalValue
' Modify the WorkspacePath preference by changing the path to "C:\"
ACADPref.WorkspacePath = "C:\"
newValue = ACADPref.WorkspacePath
MsgBox "The WorkspacePath preference has been set to: " & newValue
' this preference in effect
ACADPref.WorkspacePath = originalValue
MsgBox "The WorkspacePath preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_WorkspacePath()
;; This example reads and modifies the preference value that controls
;; the path for the database workspace file.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the files preferences object
(setq ACADPref (vla-get-Files (vla-get-Preferences acadObj)))
(setq originalValue (vla-get-WorkspacePath ACADPref))
(alert (strcat "The WorkspacePath preference is set to: " originalValue))
;; Modify the WorkspacePath preference by changing the path to "C:\\"
(vla-put-WorkspacePath ACADPref "C:\\")
(alert (strcat "The WorkspacePath preference has been set to: " (vla-get-WorkspacePath ACADPref)))
;; this preference in effect
(vla-put-WorkspacePath ACADPref originalValue)
(alert (strcat "The WorkspacePath preference was reset back to: " (vla-get-WorkspacePath ACADPref)))
GMT+8, 2026-10-28 09:44
