WindowTop 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 822| 评论: 0|原作者: admin|来自: AutoCAD
指定应用程序窗口的上边缘。
object.WindowTop
类型: 应用
此属性应用于的对象。
只读:
类型:整数
应用程序窗口的上边缘。
应用程序的上边缘由从主应用程序窗口的上边缘到屏幕上边缘的距离决定。
此距离将建立应用程序左上角的 Y 坐标。请注意,原点 (0, 0) 是左上角。
Sub Example_WindowTop()
    ' This example finds the WindowTop (X coordinate) of the WindowTop of the
    ' AutoCAD window. It then changes that position to be 100 more
    ' than it currently is. Finally, it resets the window to the
    ' original value.
    ' Find the current value of the WindowTop property
    Dim currWindowTop As Integer
    currWindowTop = ThisDrawing.Application.WindowTop
    MsgBox "The current value of WindowTop is " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
    ' Change the value of WindowTop
    ThisDrawing.Application.WindowTop = currWindowTop + 100
    MsgBox "The new value of WindowTop is " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
    ' Reset the value of WindowTop
    MsgBox "The value of WindowTop has been reset to " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
(defun c:Example_WindowTop()
    ;; This example finds the WindowTop (X coordinate) of the WindowTop of the
    ;; AutoCAD window. It then changes that position to be 100 more
    ;; than it currently is. Finally, it resets the window to the
    ;; original value.
    ;; Find the current value of the WindowTop property
    (setq currWindowTop (vla-get-WindowTop acadObj))
    (alert (strcat "The current value of WindowTop is " (itoa currWindowTop)))
    ;; Change the value of WindowTop
    (vla-put-WindowTop acadObj (+ currWindowTop 100))
    (alert (strcat "The new value of WindowTop is " (itoa (vla-get-WindowTop acadObj))))
    ;; Reset the value of WindowTop
    (vla-put-WindowTop acadObj currWindowTop)
    (alert (strcat "The value of WindowTop has been reset to " (itoa (vla-get-WindowTop acadObj))))
GMT+8, 2026-9-15 20:12
