WindowTitle 属性 (ActiveX)
获取文档窗口的标题。 支持的平台:仅限 Windows 属性值只读:是的 类型:字符串 文档的窗口标题。 言论没有其他评论。 例子VBA: Sub Example_WindowTitle()
' This example cycles through the documents collection
' and uses the WindowTitle property to create a list of all open documents.
Dim DOC As AcadDocument
Dim msg As String
' If there are no open documents, then exit
If Documents.count = 0 Then
MsgBox "There are no open documents!"
Exit Sub
End If
msg = vbCrLf ' Start with a space
' Cycle through all open drawings and get the window title of each drawing
For Each DOC In Documents
msg = msg & DOC.WindowTitle
Next
' Display a list of open drawings
MsgBox "The open drawing titles are: " & msg
可视化 LISP: (vl-load-com)
(defun c:Example_WindowTitle()
;; This example cycles through the documents collection
;; and uses the WindowTitle property to create a list of all open documents.
;; If there are no open documents, then exit
(if (> (vla-get-Count (vla-get-Documents acadObj)) 0)
(progn
(setq msg "")
;; Cycle through all open drawings and get the window title of each drawing
(vlax-for DOC (vla-get-Documents acadObj)
(setq msg (strcat msg "\n" (vla-get-WindowTitle DOC)))
;; Display a list of open drawings
(alert (strcat "The open drawing titles are: " msg))
(alert "There are no open documents!")
GMT+8, 2026-10-27 04:47
