WindowState 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 744| 评论: 0|原作者: admin|来自: AutoCAD
指定应用程序或文档窗口的状态。
object.WindowState
类型:应用程序,文档
此属性应用于的对象。
只读:不
类型:枚举acWindowState
  • acMin:窗口最小化。
  • acMax:窗口最大化。
  • acNorm:窗口正常(既不最小化也不最大)。
Sub Example_WindowState()
    ' This example reads and displays the current window state of the AutoCAD application.
    Dim CurrentState As String
    ' Use the "WindowState" variable to determine the window state of AutoCAD
    Select Case WindowState
        Case acMin: CurrentState = "Minimized"
        Case acMax: CurrentState = "Maximized"
        Case acNorm: CurrentState = "Normal Size"
    End Select
    ' Display window state
    MsgBox "AutoCAD is now: " & CurrentState
(defun c:Example_WindowState()
    ;; This example reads and displays the current window state of the AutoCAD application.
    ;; Use the "WindowState" variable to determine the window state of AutoCAD
    (setq CurrentState (cond
                           ((= (vla-get-WindowState acadObj) acMin) "Minimized")
                           ((= (vla-get-WindowState acadObj) acMax) "Maximized")
                           ((= (vla-get-WindowState acadObj) acNorm) "Normal Size")
    ;; Display window state
    (alert (strcat "AutoCAD is now: " CurrentState))
GMT+8, 2026-10-28 04:50
