ViewToPlot 属性 (ActiveX)
指定要打印的视图的名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 要打印的视图的名称。 言论若要将打印指定为视图,请将布局或打印配置的属性设置为 。PlotTypeacView 例子VBA: Sub Example_ViewToPlot()
' This example reads a list of available Named Views and displays a plot preview
' of the view selected by the user. The current view to plot,
' if set, if preceded by an '*'
' * Note: After previewing the plot, you will have to exit the
' plot preview before the VBA example will stop and control will be returned
Dim ViewList As New Collection
Dim View As AcadView
Dim iCount As Long
Dim msg As String
Dim ViewName As String, ViewNum As String
' Get list of views available to plot
For Each View In ThisDrawing.Views
ViewList.Add View
Next
' Are there any named views to plot
If ViewList.count = 0 Then
MsgBox "There are no named views to plot.", vbInformation
Exit Sub
End If
' Read and display the current plot style table path
For iCount = 1 To ViewList.count
ViewName = ViewList(iCount).Name
If ViewName = ThisDrawing.ActiveLayout.ViewToPlot Then ' Is this the current view to plot
ViewNum = iCount
ViewName = "*" & ViewName
End If
msg = msg & "(" & iCount & ") " & vbTab & ViewName & vbCrLf
Next
' Prompt user for the view to plot
RETRY:
ViewNum = InputBox("Which view would you like to plot?" & vbCrLf & vbCrLf & msg, "View To Plot", ViewNum)
If Trim(ViewNum) = "" Then
Exit Sub
End If
If Not (IsNumeric(ViewNum)) Then
MsgBox "You must supply a numeric value corresponding to one of the views listed above.", vbExclamation
GoTo RETRY
End If
' Tell the drawing which view to plot
ThisDrawing.ActiveLayout.ViewToPlot = ViewList(CLng(ViewNum)).Name
' Make sure you tell the drawing to plot a view, not some other plot style
ThisDrawing.ActiveLayout.PlotType = acView
' Send Plot To Window
ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
ThisDrawing.Plot.DisplayPlotPreview acFullPreview
可视化 LISP: (vl-load-com)
(defun c:Example_ViewToPlot()
;; This example reads a list of available Named Views and displays a plot preview
;; of the view selected by the user. The current view to plot,
;; if set, if preceded by an '*'
;; * Note: After previewing the plot, you will have to exit the
;; plot preview before the VBA example will stop and control will be returned
;; Get list of views available to plot
(setq viewList (vlax-make-safearray vlax-vbObject (cons 0 (vla-get-Count (vla-get-Views doc))))
cnt 0)
(vlax-for view (vla-get-Views doc)
(vlax-safearray-put-element viewList cnt view)
(setq cnt (1+ cnt))
;; Are there any named views to plot
(if (> (vla-get-Count (vla-get-Views doc)) 0)
(progn
;; Read and display the current plot style table path
(setq iCount 0
msg "")
(while (> (vla-get-Count (vla-get-Views doc)) iCount)
(setq viewName (vla-get-Name (vlax-safearray-get-element ViewList iCount)))
(if (= viewName (vla-get-ViewToPlot (vla-get-ActiveLayout doc))) ;; Is this the current view to plot
(setq ViewNum (1+ iCount)
ViewName (strcat "*" ViewName))
(setq iCount (1+ iCount)
msg (strcat msg "(" (itoa iCount) ") " viewName "\n"))
;; Prompt user for the view to plot
(setq viewNum (vla-GetInteger (vla-get-Utility doc) (strcat "\nWhich view would you like to plot?\n" msg)))
(if (and (<= viewNum (vla-get-Count (vla-get-Views doc)))
(> viewNum 0))
(progn
;; Tell the drawing which view to plot
(vla-put-ViewToPlot (vla-get-ActiveLayout doc) (vla-get-Name (vlax-safearray-get-element ViewList (1- viewNum))))
;; Make sure you tell the drawing to plot a view, not some other plot style
(vla-put-PlotType (vla-get-ActiveLayout doc) acView)
(vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3")
;; Send Plot To Window
(vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview)
(alert "The view number entered is not valid.")
(alert "There are no named views to plot.")
GMT+8, 2026-10-28 05:25
