ViewportOn 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 876| 评论: 0|原作者: admin|来自: AutoCAD
指定视口的显示状态。
object.ViewportOn
类型: PViewport
此属性应用于的对象。
只读:不
类型:布尔
  • True:视口已打开。
  • False:视口关闭。
若要打开或关闭视口的显示控件,请使用该方法。Display
Sub Example_ViewportOn()
    ' This example creates two new paper space viewports.
    ' It then checks the status of the viewports.
    Dim pviewportObj1 As AcadPViewport
    Dim pviewportObj2 As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the paper space viewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 10
    height = 10
    ' Change from model space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paper space viewports
    Set pviewportObj1 = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    center(0) = 8: center(1) = 8: center(2) = 0
    width = 10
    height = 10
    Set pviewportObj2 = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    ' Before making a paper space viewport active,
    ' the mspace property needs to be True
    pviewportObj1.DISPLAY (True)
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = pviewportObj1
    MsgBox "pviewportObj1 is " & (IIf(pviewportObj1.ViewportOn, "on.", "not on.")) & vbCrLf & _
           "pviewportObj2 is " & (IIf(pviewportObj2.ViewportOn, "on.", "not on."))
    ' Now turn on pviewportObj2 as well
    pviewportObj2.DISPLAY (True)
(defun c:Example_ViewportOn()
    ;; This example creates two new paper space viewports.
    ;; It then checks the status of the viewports.
    ;; Define the paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 10
          height 10)
    ;; Change from model space to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the paper space viewports
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj1 (vla-AddPViewport paperSpace center width height))
    (setq center (vlax-3d-point 8 8 0)
          width 10
          height 10)
    (setq pviewportObj2 (vla-AddPViewport paperSpace center width height))
    ;; Before making a paper space viewport active,
    ;; the mspace property needs to be True
    (vla-Display pviewportObj1 :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc pviewportObj1)
    (alert (strcat "pviewportObj1 is " (if (= (vla-get-ViewportOn pviewportObj1) :vlax-true) "on." "not on.")
                   "\npviewportObj2 is " (if (= (vla-get-ViewportOn pviewportObj2) :vlax-true) "on." "not on.")))
    ;; Now turn on pviewportObj2 as well
    (vla-Display pviewportObj2 :vlax-true)
GMT+8, 2026-10-28 06:10
