VBE 属性 (ActiveX)
获取 VBAIDE 扩展性对象。 支持的平台:仅限 Windows 属性值只读:是的 类型:Microsoft VBE 对象 VBAIDE 扩展性对象。 言论此特性允许您从AutoCAD的对象模型访问VBA IDE对象模型。如果 VBAIDE 不可用,则该属性将引发异常。例如,如果尚未加载 acvba.arx 应用程序,则 VBAIDE 不可用。 以下代码行返回活动 VBA 项目描述字符串的名称: ThisDrawing.Application.VBE.ActiveVBProject.Description 例子VBA: Sub Example_VBE()
' This example uses the VBA IDE extensibility model to dynamically
' create a VBA subroutine. After running this example, see the first line of code
' in the VBA IDE code window to see a new subroutine. Then
' remove the new subroutine before continuing.
Dim VBEModel As Object
Dim newRoutine As String
Set VBEModel = VBE ' Get the VBE object
' Define new subroutine to be added. This could be created dynamically from user feedback.
newRoutine = "Sub Dynamic_Procedure()" & vbCrLf
newRoutine = newRoutine & vbTab & "MsgBox ""New subroutine.""" & vbCrLf
newRoutine = newRoutine & "End Sub" & vbCrLf
' Insert new subroutine
VBEModel.CodePanes(1).CodeModule.InsertLines 1, newRoutine
MsgBox "A new subroutine was added called Dynamic_Procedure."
可视化 LISP: (vl-load-com)
(defun c:Example_VBE()
;; This example uses the VBA IDE extensibility model to dynamically
;; create a VBA subroutine. After running this example, see the first line of code
;; in the VBA IDE code window to see a new subroutine. Then
;; remove the new subroutine before continuing.
;; Note: You might need to add a code module to the default project first.
(setq VBEModel (vla-get-VBE acadObj)) ;; Get the VBE object
;; Define new subroutine to be added. This could be created dynamically from user feedback.
(setq newRoutine (strcat "Sub Dynamic_Procedure()"
"\n MsgBox \"New subroutine.\""
"\nEnd Sub"))
;; Insert new subroutine
(vlax-invoke-method (vlax-get-property (vlax-invoke-method (vlax-get-property VBEModel 'CodePanes) 'Item 1) 'CodeModule) 'InsertLines 1 newRoutine)
(alert "A new subroutine was added called Dynamic_Procedure.")
GMT+8, 2026-10-27 09:45
