UseStandardScale 属性 (ActiveX)
指定绘图是使用标准比例还是自定义比例。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论若要指定要在绘图中使用的标准比例,请使用该属性。若要指定自定义比例,请使用该方法。StandardScaleSetCustomScale 例子VBA: Sub Example_UseStandardScale()
' This example will access the Layouts collection for the current drawing
' and list the status of UseStandardScale for each Layout.
Dim Layouts As AcadLayouts, Layout As ACADLayout
Dim msg As String
' Get layouts collection from document object
Set Layouts = ThisDrawing.Layouts
msg = ""
' Get the UseStandardScale information of every layout in this drawing
For Each Layout In Layouts
If Layout.UseStandardScale Then
msg = msg & Layout.name & " uses the standard scale." & vbCrLf
Else
msg = msg & Layout.name & " uses a custom scale." & vbCrLf
End If
Next
' Display the information
MsgBox msg
可视化 LISP: (vl-load-com)
(defun c:Example_UseStandardScale()
;; This example will access the Layouts collection for the current drawing
;; and list the status of UseStandardScale for each Layout.
;; Get layouts collection from document object
(setq Layouts (vla-get-Layouts doc)
msg "")
;; Get the UseStandardScale information of every layout in this drawing
(vlax-for Layout Layouts
(if (= (vla-get-UseStandardScale Layout) :vlax-true)
(setq msg (strcat msg (vla-get-Name Layout) " uses the standard scale.\n"))
(setq msg (strcat msg (vla-get-Name Layout) " uses a custom scale.\n"))
;; Display the information
(alert msg)
GMT+8, 2026-10-27 08:59
