User 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 773| 评论: 0|原作者: admin|来自: AutoCAD
User 属性 (ActiveX)
获取 PreferencesUser 对象。
object.User
类型:偏好
此属性应用于的对象。
只读:是的
类型:PreferencesUser
获取对象。PreferencesUser
该对象保存存储在注册表中的“选项”对话框的“用户”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesUserDatabasePreferences
Sub Example_User()
    ' This example obtains a reference to the User Preferences object
    ' from the Application Preferences object, and reads one of the User
    ' preferences
    Dim ACADPref As AcadPreferencesUser
    ' Obtain a reference to the User Preferences object
    Set ACADPref = ThisDrawing.Application.preferences.User
    MsgBox "You now have access to the properties and methods of the User Preferences object!"
    MsgBox "The User preference KeyboardAccelerator is set to: " & ACADPref.KeyboardAccelerator
(defun c:Example_User()
    ;; This example obtains a reference to the User Preferences object
    ;; from the Application Preferences object, and reads one of the User
    ;; preferences
    (alert "You now have access to the properties and methods of the User Preferences object!")
    (alert (strcat "The User preference KeyboardAccelerator is set to: " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 04:50
